Big 1/4 Mile Analysis - Centerline and JoeJ Ernst
Old Apr 26, 2016 | 03:20 PM
99lightning's Avatar
99 ford lightning
yes folks shy away from that tank, if im cruising on the highway and creeping into its fine. dead stop with it shifting and the car spinning even part throttle the temps shoot up. and then when you ease back on the gas pedal the temps climb before recovery. save your self the wasted trips to the track do not buy that tank.
Old Apr 26, 2016 | 05:05 PM
Rocman8's Avatar
E55
You need to find a plastic hose that's about 5/8 O.D. and shove it in the bottom hole inside the tank and run that hose to the back corner of the tank. I also took out the foam that was in there and put a piece of RCI fuel cell foam in the tank which also holds the hose down into the bottom of the tank so it never sucks air into the pump.
Old Apr 26, 2016 | 05:56 PM
cnterline's Avatar
2003 SL55,2020 GTC ,2017 GTS sold ,2002 G500 Sold,2003 SL500 Sold,
5 gallon never had a problem
Old Apr 27, 2016 | 03:33 PM
Rocman8's Avatar
E55
Do you know what kind of lid that is or where you can buy them?
Old Apr 27, 2016 | 08:38 PM
cnterline's Avatar
It came on the tank ,but I would guess a marine supply store
