Sl65 2-piece wheel question
I have the 2-piece SL65 wheels on my car and was going to seperate the 2 halfs for refinishing. My question is am I breaching any seals when the parts seperate causing potential leaks when reassembling? Through the bolt holes or the center section to the outer rim?
00 C200 & 00 C55 & 06 SLK55
If i'm not wrong; these Rim face bolts should to torque around (22-25 ft/lbs)>>(32-34 Nm),,
more than that will split the bolt head or damage the bolt thread or squeeze the seal more than it should..!!
ZAYED,,
ZAYED,,
