Blowing white smoke (video)
Old 05-15-2016, 09:34 AM
alexanderfoti's Avatar
2013 W204 C63 AMG, 2008 W221 S65 AMG
Hi all
Took my CL55 for a 100 mile drive back yesterday. All good no issues.
This morning, started it to do some wiring stuff, turned it off etc. When I finished up, I noticed a large amount of water on the floor to the back of the car.
Started it up outside and am greeted with this:
Not quite sure whats happened. The smoke is mostly white, doesn't smell of oil. Possibly of fuel. The popping of the exhaust is also a new one, hasn't happened before!
Recent work includes removing the supercharger and re-installing it. I also moved my water/meth injection nozzles to here:
There appears to be no leaks, inlet or otherwise.
I am wondering if the MAP sensor has decided it wants to die, and that is screwing up my fuelling. Map readings seem OK though.
Old 05-15-2016, 09:55 AM
I have about -9.7 ish at idle and it fluctates to around -10.02psi at 2500 rpm.
It does blow the smoke under load in gear, but its darker and not as much.
Old 05-15-2016, 10:32 AM
Hulk's Avatar
A Merc
Might be head gasket. Can you do a compression test?
alexanderfoti (05-15-2016)
Old 05-15-2016, 11:13 AM
I think its the IC in the supercharger leaking coolant into the inlet.
I have a split cooling system and its header tank was empty. Bit odd, as I had just filled it up.
Filled it up again, ran it for 15 minutes with the charge pump actuated. It dropped about 5mm in my small header tank.
There is also physical water droplets condensing on my exhaust tips.
Will try and do a compression test at some point soon. The engine coolant tank hasn't dropped, oil cap has no mayo on it, and oil still looks gold.
Old 05-15-2016, 11:20 AM
Rocman8's Avatar
E55
Pull a surge tank off and look at the intercooler with a mirror while running the pump.
Old 05-15-2016, 11:25 AM
Good idea. Will give it a go.
Old 05-15-2016, 12:09 PM
Hulk's Avatar
A Merc
Are you using a check valve or solenoid?
Old 05-15-2016, 12:16 PM
Just finished doing that. Am seeing no coolant on the other side of the IC
Old 05-15-2016, 12:22 PM
Check valve, but since the smoking started, I removed the water injection tube to check it wasn't flowing all the time. I have disconnected the controller for now to eliminate water going in at idle as the cause.
I have lots of oil sat on top of my valves when they are closed:
and this:
I think Im going to pull the heads.
Old 05-15-2016, 12:28 PM
Hulk's Avatar
A Merc
Holy crap that's a lot of oil! pull the heads
Old 05-15-2016, 12:29 PM
problem is, ill pull the heads, find the rings and bores are scored, then will need to replace the engine I think.
Old 05-15-2016, 12:35 PM
1ForcedBenz's Avatar
Benz
Make sure your engine oil isn't over filled inadvertently. And disconnect the pcv lines at the valve covers that's the only oil would be able to get behind your valves like that if assuming your engine is mechanically ok.
Old 05-15-2016, 12:36 PM
Engine oil is just under max on the dipstick.
I disconnected the 2 rubber pipes going into the tanks on the top of the rockers, no smoke coming out of them at all at idle.
Old 05-15-2016, 12:46 PM
Rocman8's Avatar
E55
What dipstick?
Old 05-15-2016, 12:50 PM
Mines a CL55, with the dipstick included.
I post engine faults in here, as the 211 forums have many more views, and they are the same engine.
Old 05-15-2016, 01:02 PM
Rocman8's Avatar
E55
Ahhh maybe something different with US cars cause even the CL55's I've seen have a cap instead of a dipstick.
You should still check compression.
Old 05-15-2016, 01:12 PM
Hulk's Avatar
A Merc
Ya do a compression test. Is the car misfiring? Any codes?
Old 05-15-2016, 03:04 PM
Not done one yet. My compression tester keeps leaking at the spark plug seat.
Not missing until my last test drive, suspect it fouled up the plugs. It's back to normal now. Will idle all day happily. Both breathers are clear.
No codes
Old 05-16-2016, 07:31 AM
Right.
No 1 plug:
No 2 plug:
Compression test:
1 - 155psi
2 - 165psi
3 - 160psi
4 - 175psi
5 - 160psi
6 - 175psi
7 - 175psi
8 - 175psi
Old 05-16-2016, 08:19 AM
Hulk's Avatar
A Merc
Compression is ok, the plugs are not. Did you remove the heads yet?
Old 05-16-2016, 08:25 AM
Agreed, Not yet. I have to get the car to my mechanic, as I don't want it stuck where it is.
Old 05-16-2016, 08:45 AM
Rocman8's Avatar
E55
So most likely valve guides it seems.
Old 05-16-2016, 09:17 AM
Possible. The surge tank was oily on the inside, above no 1 as well. I think the oil is getting sprayed up from the cylinder when the piston is on its way up.
Old 05-16-2016, 09:48 AM
Former Vendor of MBWorld
shardul's Avatar
2003 W211 E55, 2003 W220 S600
do a leak down,
Old 05-16-2016, 09:49 AM
Originally Posted by shardul
do a leak down,
Haven't got a tester. Will have to wait until it gets to the mechanic.
Quick Reply: Blowing white smoke (video)
