Ethanol Destroyed Fuel Pumps
2004 E55,1969 300SEL6.3,2011 ML350 BlueTec Diesel,2005 ML400 CDI
I found a 2005 E55 Wagon with 22K miles. The car has been sitting in a garage for more than 4 years. After installing a new battery the Airmatic pumped up, but no way would it start and it was obvious the pumps were not operating.
So after 4+ years of sitting in 10% ethanol 93 octane gasoline stew with obvious phase separation, here is the result:
The insulation on the wires is totally gone.
The interconnecting hoses are so brittle that they shatter like glass to the touch.
The photos speak for themselves.
I'm guessing the injectors, rail and lines are all corroded.
Other than that the car looks as if it just came of the showroom floor.
This is like saying that going to the bottom of the ocean will kill you with hypothermia.
That's not what will kill you.... First.
Gas sitting in a tank is gas sitting in a tank. That 10% E is not the culprit here.
However, ethanol attracts water. When the two combine, they create the perfect environment to grow a type of bacteria called acetobacter. The acetobacter poop out acetic acid and acetic acid is very corrosive.
The EPA may have it’s way soon and bump up the ethanol content of gasoline to 15 percent.
My 2004 is stored 7-8 months each year with ethanol-free gasoline. FWIW, here are the pumps at 65K and were still working perfectly when replaced.
Interesting metaphor and yes, ethanol itself is not particularly corrosive. When the oil companies first started blending ethanol in gas, it corroded some rubber and plastic gaskets on some cars and equipment. Manufacturers figured it out and substituted new materials.
Well, I am no Walter White, but in my 55 years of playing with automobiles, I have seen plenty of cars that were parked for years with old gasoline, but I have never seen anything like this. Whether it's bug doodoo or just ethanol, the metamorphosis of the plastic seals, hoses and fuel level floats is undeniable.
PLATINUM SPONSOR
Great pictures! The greenish color on the copper wires almost looks like it was exposed to some water/air and or electrolysis.
You may want to replace all the fuel lines, clean out fuel rail , check injectors in addition to cleaning the tank.
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
www.ultimatepd.com
Could an octane booster (with benzene and other solvents in it) explain this? Seems you wouldn't really know what was in the tank. Maybe Race fuel?
Not a chance. This is a absolutely a virgin E55 which, due to unusual circumstances, has been sitting in a garage for 4+ years and was rarely driven prior to being parked. Only 22K miles on the clock.
Because of our ethanol laced gas our North American W211's got these horrible plastic gas tanks that deform and leak.
Have that car towed to Mercedes dealer and they can deal with replacing the tank and pumps. Maybe you can get them to replace injectors or anything else fuel related that is damaged (extended warranty is for fuel system)
What does every other country get? Metal tanks? The plastic tank is lined with what looks like teflon. They knew what they were doing, in that particular case. I do not currently believe any other countries got anything other than plastic tanks.
"Ethanol laced" - Instead of "MBTE laced"? Or "Lead Laced"? I will take ethanol.
If you can get it for that price it's a good deal but I wouldn't let it go for a penny under $20K with those miles.
