Low dyno numbers
Old 05-27-2016, 04:00 PM
Ruthle55's Avatar
e55 amg
Originally Posted by sexyxe
If you're stock, doing it in 4th, it was the third pull. You've probably heat soaked a touch and have started to add some fuel and drop some timing. Wouldn't get too sexed up about it. Hit the track. Run a low 12 high, 11 at 118-120 and you'll be in the right range.
A stock e55 amg does not trap 120. And rarely traps 118. If it does, a lot of people are owed money for the misrepresentation of how much power a certain tune/mod adds.
HeissRod (05-27-2016)
Old 05-27-2016, 08:38 PM
sexyxe's Avatar
04 E55
That's my mistake, I often think of my old car when thinking of trap speeds as I tracked it a lot more than the 55.
Old 07-23-2016, 06:49 PM
seanol's Avatar
2004 AMG E55
Hey guys!
New here but not to dynos.
OP, What gear did you dyno in? Lower gears will show lower horsepower on an inertia dyno.
HTH,
Sean
Old 07-23-2016, 06:52 PM
Dato55's Avatar
2005 e55
Originally Posted by seanol
Hey guys!
HTH,
Sean
I believe it was 3rd and 4th
Old 07-23-2016, 06:54 PM
seanol's Avatar
2004 AMG E55
If you dyno in third I would think those numbers are expected. Low four fourth. You would not have the same numbers for each gear in any event.
Look at the mph on the readout and compare it to your daily drive to determine the gear run.
If you have the raw data files I can always plot them for you.
Sean
Old 07-23-2016, 07:07 PM
chawkins2001's Avatar
2006 E55 AMG
I am sure figured things out by now, but I dynode 365rwhp/430rwtq I believe back in the day. I did a comp test for piece of mind and modded it to hell. Car ran like a bat out of hell!
These cars should be pulled in 3rd gear btw.
Old 07-23-2016, 07:11 PM
  #32
seanol's Avatar
2004 AMG E55
It really depends on what type of dyno you run on regarding numbers. A load style dyno will show lower numbers than an inertia dyno. It is all in how they measure. If you stick to the same type of dyno then comparisons of power and changes can be accurately correlated.
I have a write up I did from another forum I can post if that would help. A bit much for one post though.
Sean
Old 07-23-2016, 07:24 PM
  #33
Dato55's Avatar
2005 e55
As soon as I get the car back after transmission work I will definetly do a compression test
Old 07-23-2016, 07:27 PM
  #34
Dato55's Avatar
2005 e55
Sean
Honestly I think the car is pretty healthy, I just saw how people were putting down around 400 to the wheels so I got scared something might not be right
Old 07-23-2016, 07:32 PM
  #35
seanol's Avatar
2004 AMG E55
You may be perfectly fine. Depends on what numbers you are comparing. You want to run the car in the trans ratio that is closest to 1 to 1 i.e. i rpm for 1 tire revolution. This has the least amount of parasitic loss.
If that is third then compare your numbers with others who ran in third on an inertia dyno and you should be within 3 to 5% depending on the repeatability of the car.
You should stay with the same brand, Dynojet to Dynojet to remain accurate as each manufacturer uses different calculations. Also, pick a correction factor as well. Either SAE or STD. I always used SAE as I found it covered a broader range of conditions.
Good luck,
Sean
Old 07-23-2016, 07:42 PM
  #36
seanol's Avatar
2004 AMG E55
I have been researching and you guys came up as one of the better solutions to cooling. Are you still making the kits? Price and availability? Won't be until fall but I like to plan ahead.
On another note, why third? I have not looked at the trans ratio's yet, is it closest to 1 to 1?
Thanks,
Sean
Old 07-23-2016, 07:43 PM
  #37
Dato55's Avatar
2005 e55
Good luck,
Sean
I did a bunch of maintenance on it and got a lighter torque converter so it will probably put down different numbers
Quick Reply: Low dyno numbers
