OIL TEMP
I've discussed this issue at length with my trusted and very knowledgeable amg tech. Further input from the forums and PL lead to my conclusion: it's fine. Different cars run at different temps with different variables. My tech has thoroughly gone over my car and said it runs, behaves and measures like it should. Consensus is that if the oil temps are out of acceptable range, you'll get a cel and red gauge.
That being said, I still keep an eye on it and typically drive with that menu screen up (oil temp and gear # in the gauge cluster info).
Search oil temps here and in the W204 section. Also google it. You'll find some info.
More specifics would help. Also, search on here for some of the buzz words you used. There are numerous posts and threads with video clips of various engine noises with folks wondering if it is normal. As mentioned before, also search W204 section. They also have the M156 engine and it is a very active section.
Oil temp off the AMG screen reads in Celcius and will blink until it hits 80 degrees. So, I don't punch it before the temps warm up. Ive removed the fog lights and run black mesh on both sides so I get a lot more airflow to the oil cooler then stock.
My temps get up around 95-100 degrees cruising around nothing major. Ive seen it go above 100 when I drive it hard but it comes back down pretty quick.
Everything seems ok.
i use Motul 6100 or 8100 oil with Liqui Moly MoS2 and have not heard lifter tick/rattle once. when I ran Mobil 1 with Liqui Moly MoS2, I got tick/rattle 3 times.
its so loud it sounds like knock...had me really really worried and wouldn't go away until i got past 20mph...
Regards,
Will
