Manual mode and paddles not working
So I got a scanner and my car has the upshift steering wheel pulsing between operating and non operating. Only for the upshift. I cut off all paddle button wiring from the wheel and still it upshifts. Could it be my car is an early 2005 and still analog? I have WIS but can't tell where the wires go. I think it's circuit s111/1. Any ideas?
Chris
I did not check the wires but I have replaced my steering wheel with one with wires intact, i want to say it was 3 wires like you said for an 05. With my scanner I see the steering column module reads my paddle shifts correctly, and I have replaced my transmission module with still no luck. I see the steering module feeds into the CAN-C and then the transmission module. I want to test voltages and continuity but I cannot find which connector is which online, and I am unsure if disconnecting wires and hoping for the best is the next course of action. What should I do to test the CAN? I really am stuck here. No matter what the transmission module thinks someone is mashing that upshift button from the steering wheel (not the floor shifter, i checked).
what was changed on the car since the last time the steering wheel shift buttons worked properly?
Since I bought the car I have had the problem. I've replaced the steering wheel and the transmission module. I've also replaced the transmission, but the issue was before and after the transmission. I got the car about 10k miles ago
IF you are reading the steering wheel shift buttons as working properly when scanning the SCM ... and you are reading the touchshift (both down AND up) as working properly when you are scanning the shifter. Then I would question if you have the correct TCU (is it for a 2005 or later?) . IF there were a wiring issue between the SCM and the can or the tcu and the can, I would think you would be getting communication error codes.
#32
When you say that it was "bad" ... was it just reading wrong (like too low ... when the level was fine)?
#33
#34
I am curious about this too. I mean don't get me wrong at this point I'll try nearly anything, but are there any signs it's bad? Or is it kinda a shot in the dark? I think I've read the same thing somewhere else. Wiring diagrams don't show it's related but who knows at this point
#35
No they just did not work or work correctly. Do a search and it should come up as to the issue and fix but I know for whatever reason the circut runs through the oil level sensor...
You know....Mercedes engineering !!LOL
Andres Morejon (12-31-2022)
#36
![](https://cimg7.ibsrv.net/gimg/www.mbworld.org-vbulletin/2000x1504/20220725_111811_65d9bb24a730d56eeee6aa728fe92608798341db.jpg)
#39
I have the can bus C exposed, and I have the wiring diagram, but there is no way that I know to know which cable is the one im looking for to the TCU. Any help on how to identify it? Thanks for any help
#40
This thread is the closet i can find to my issue so im bringing it back.
My 2003 S55 AMG paddle shifters have never worked since i got the car. The floor shifter works with manual mode as designed however nothing happens at all with either paddle shifter.
I found distronic/voice command selector in my trunk labeled for an 02 s600 that someone either planned to install for some reason. Maybe in an attempt to fix random distronic errors. The voice command stalk on my wheel right now is not on and was located in the trunk so maybe they just planned to fix that. Is that part in anyway connected to the paddles? Part is same as linked https://www.ebay.com/itm/15221643729...mis&media=COPY
I also have no idea what may have been replaced in the past. Would the shift selector maybe be an issue? Why do those need to be replaced/repaired?
Just kind of wondering where to start looking. Doesnt seem like an issue with paddle wiring because the manual mode works fine with the floor selector unlike previous posters.
#41
Given the configuration of this early version of AMG shift buttons, the fact that your touch shifter functions WHILE your steering wheel shift buttons do not .... pretty much rules out a problem with the shift buttons and/or wiring (if your shift buttons were NOT plugged in OR there was a break anywhere in the wiring, the car would interpret that as you pressing the "UP" shift button ... thereby disabling the floor shifter touch-shift function).
On these "early amg shift buttons config" cars, the floor shifter is programed for steering wheel shift buttons while it is still a virgin. Once it has been driven some, this can not be changed. So, your shifter was likely replaced with a used shifter from a non-amg car OR, it was replaced with a new shifter, BUT the installer failed to set it for AMG shift buttons.
Hope that helps.... if you have more questions feel free to send me a note a Latemodel21@yahoo.com
Chris
Aggrorider1 (07-10-2024)
#42
Yes, your 2003 S55 does have the same steering wheel shift button (electronic) configuration as the 2003-2004 E55 & CLK55 (along with the 2003-2006 SL55/65, CL55/65, S55/65 and SLR McLaren), so it does make sense to pose this question here. You have done a great job of gathering the essential clues to your issue and have already guessed the most likely correct answer (floor shifter was replaced with one that was not coded for AMG shift buttons is more than likely what has happened).
Chris
Chris
#43
Since the floor shifter is a "theft related" part (tied to "drive authorization") a swap with a used part wont work (unless you change out the ECU, EIS and possibly CGW and more .... at the same time), so a new shifter may be the only way to solve this (make SURE that they know the new unit must be coded for steering wheel shift buttons if you go this way).
Best of luck,
Chris
