Can I purchase just an idler / tension pulley sleeve?
Old Aug 20, 2016 | 07:54 PM
moehler's Avatar
2014 CLS 63 S AMG / 2004 E55 AMG
I just replaced my eurocharged idler pulleys (combined serpentine / SC) with a UPD set because the serpentine pulley got so loose that it chattered against the SC pulley. When I pulled it out, the bearing was very loose within the housing. I have no idea what caused it.
I just installed a UPD pulley set and right away notice a slight wobble in the the serpentine pulley. I'm now paranoid that the wobble will eventually wear the pulley down prematurely. All other pulleys are stock and have zero wobble / movement.
There's only two things that I can think of that would cause the wobble, (1) the pulley is slightly off / imbalanced, or (2) the pulley sleeve is messed-up.
While the sleeve visually looks more or less perfect, if it's cheap, I'd like to just replace it. Does Mercedes sell just the pulley sleeve? I've only found it sold as a set with the stock pulleys (~$500).
Old Aug 20, 2016 | 08:34 PM
210lvr's Avatar
2004 E55
my bad, i should of read this post. i read your other one but it seams you already discovered the same thing i found. my advice is OEM all the way.
