Torque Converter - are they all the same "stock"
So still having the issue with the trans between 1500 and 2500, where under part throttle it gets a little jittery. the Transfluid change helped, but not fully. the glycol test showed no glycol. So now I was thinking maybe I should just replace the TC. seems the consensus is that the Lockup function it having an issue. I need to hook up my DAG and disable lockup and see if that makes it shift smoother. So the question is, if it is the TC, did AMG do anything special with the stall rating on the AMG models or does it not matter. I have seen AMG E55 Stock "Specific" TCs and then some sights will have the same part number for an E55 or E500.
Thanks in advance.
Jeff
Thanks in advance.
Jeff
![](https://mbworld.org/forums/images/ranks/veteran_army.png)
Nope they are not stock throughout all models and watch out for spammers who say otherwise!!-----use EPC to find the correct part less you will be back whining!!
Thanks in advance.
Jeff
Thanks in advance.
Jeff
The first 3 numbers and the 7th and 8th number stamped on the torque converter that give it what type it is, my e320cdi has a 211-13 type torque converter but the number stamped on it is A 211 250 13 02
They do have different bolt hole sizes and diameters, from the research Iv done, if you get a TC with matching numbers as above, it's should be the same fitting and functioning as the one it replaces.
I hope my information was helpful.
