IAT 199f ?
i would like to know if someone faced this issue,,
my car is tuned by euroflash
,,mods are
77 fixed pulley, 168 crank pulley, ftp intercooler, Ic tank, upgraded water pump, 3” exhaust x pipe, barabus mufflers, NGK one step colder sparks, k&n filters.
my car is running lean and my IAT is running 190F to 199F in hard pulls and yes its puuling timing and my power drop,
in my country its winter and the ic tank water is cold during my hard pulls and the water pump is directly switch from the cabin and works fine, supercharge doesn't shut-down in every hard pulls
even thug my IAT is so high, recently changed my fuel pump and filter.
Check out the dyno pull and datalog,,, do you think i need to get me a better tune !!
Doesn't mean the pump is not dead itself but that there is power and that it holds steady through the rpm.
that's a great idea,
as per to my setup on/ off its manual as soon I switch the fog light on the pump works , and I think its better to keep it on always.
THANK YOU SIR
I will try to restore my pervious is split and bmw reservoir.
Put a hose in the tank on the pick up side and it will work, or better yet weld in a line
MERRY CHRISTMAS!
thank you sir
kindly check out the attached pic and advice me
and how about bleeding anything particular for this kind of tanks ?
Merry Christmas to you and your family
