Car WONT turn off!
Old Dec 27, 2016 | 07:36 PM
TonyGia's Avatar
W211 P030 E63 AMG // W204 C63 Coupe
Car WONT turn off!
So heres a question. Had an issue with my car NOT turning off. As in key-out and everything off, except motor.
Tried cycling between key-in on/off, also keyless on/off.
Tried locking car and tried again.
Steering wheel would lock, but shifter would still work in all gears.
AFTER the problem presented itself, car displayed SRS, ESP,a nd pre-safe warnings.
Car turned off by itself after there was nothing I could do, problem hasn't arose since. Car has always been babied for the 6.5 years I've owned, garage-kept, no water leaks anywhere either...
Ummmm.. help?
Old Dec 27, 2016 | 11:46 PM
mightar's Avatar
Veteran: Navy
V60 Polestar, Veloster N 6MT
Check to see if the central gateway is faulty.
Old Dec 27, 2016 | 11:57 PM
TonyGia's Avatar
Common problem? If it does what I think it does then this sounds like a costly sorta nightmare
Old Dec 28, 2016 | 12:42 PM
Rocman8's Avatar
E55
I've seen this a couple times where the front Sam fuse box cover was left loose allowing water into the module and short circuits. Happens exactly how you describe it even with the warning lights. I forget which relay it is in that box but if you remove it then the engine will turn off.
Old Dec 28, 2016 | 11:21 PM
mightar's Avatar
Veteran: Navy
Fairly common - quite a few hits from a forum search. Price should be under $200.
Old Jan 1, 2017 | 02:51 PM
210lvr's Avatar
2004 E55
this. I had an sl come in about 6 months ago that did this. Same thing I think I pulled the 87 relay and it would shut off. I thought the relay was sticking but nope. This guy didn't have any liquid damage but same symptoms. Whatever relay it was I threw a front Sam at it and she was good to go.
Old Jan 1, 2017 | 07:12 PM
GatorMB's Avatar
2002 CLK 55 AMG cabriolet Eurocharged
I jumpered my AC compressor after replacement.
Went for a beer run and found the same phenomena. I suspect there is 12v shorted in the front sam if applicable.
Disconnect battery and unscrew the engine bay fusebox for an inspection.
If nothing is found start unplugging fuses one at a time. The ECU is receiving false input from an internal short in the harness or sub-system. Hopefully it is simple.
Cheers
