08' e63 gear shifter gets stuck
Old Dec 31, 2016 | 01:42 PM
drey88's Avatar
2008 E63 AMG
Hey guys, so recently mug ear shifter had been getting stuck from park into reverse and from neutral into reverse. I really have to play with it for it to get dislodged. Is this an electrical problem and is anyone familiar with it.
Old Jan 1, 2017 | 01:32 AM
Rocman8's Avatar
E55
Disconnect the shifter linkage under the car and see if the issue is still there.
Old Sep 24, 2021 | 05:40 PM
Jamal01's Avatar
c300 2010
how did you solve this?
i am having same issues
Old Oct 23, 2021 | 09:47 PM
E63007's Avatar
07' E63
When I did my Rear Main, which then turned into a full rebuild from that point back, I had ordered the little bits that comprise the little bushings, lock rings etc of the shifting linkage and was slightly impressed with how it felt, I say slightly because after replacing every bushing in the rear suspension, shocks, Airbags, Drive discs, Tranny Valve Clean, steering rack bushings, Brakes,rotors, 3.06 Ring & Pinion, the shift linkage was a slight improvement in comparison to everything else!
I will say that although I had slightly less smooth shifting before that particular upgrade, I cannot see how linkage would effect what your talking about. That, to me, seems like a transmission valve or gear issue???
