6.3 oil leak question
Old Jan 4, 2017 | 08:05 PM
Forrest Gump 9's Avatar
shrimp boat
Hello all
I'm looking to buy my first AMG with the 6.3l engine. Everything checked out fine except for this
Is that normal on the 6.3L engine? Valve cover gasket like the 5.5? Thank you for your guidance
Old Jan 4, 2017 | 08:11 PM
Rocman8's Avatar
E55
pretty common. there is a valve cover gasket and the front cylinder head cover gasket. they both should be done at the same time.
Old Jan 5, 2017 | 04:41 PM
ToeCutter's Avatar
E63
Mine E63 in the shop for valve cover leaks
It got bad enough that it started to burn on the exhaust. Dealership said $800-$900. LOL. That will be the smallest bill I ever got. It's not a poor mans car.
Old Jan 5, 2017 | 08:29 PM
Dublinoh's Avatar
E63 AMG 2007
That's good advice to do both, I didn't know and in less than a year a second leak (Mercedes dealership called it a timing cover gasket) cost me way more than had it been done the first time.
Old Mar 15, 2019 | 09:49 AM
dustinN's Avatar
09E350, 07E63, 13CLS63
I think I have the leak from the cylinder head top front cover, on the right. Can someone please let me know the part number for Timing cover gasket? Can this be a DIY? Is there a procedure for this? I couldn't find one. Thanks.
Old Mar 16, 2019 | 01:03 AM
maxusa's Avatar
2013 E63 P30, 2010 GL550
I m just curious if you realize this is a 2+ year old thread you replied to.
Old Mar 18, 2019 | 05:07 PM
hachiroku's Avatar
SPONSOR
2007 Mercedes E63 AMG
if you're doing the front cover i'd recommend doing all your gaskets, seals, o-rings, etc. this will help avoid repetitive work when another seal leaks. more money upfront for an inevitable leak to come with mileage.
valve covers
front chain seal
oil cooler thermostat o-ring
oil cooler hard line o-rings
oil pans if leaking...upper pan should be done with front chain cover as they'll share a joining face. lower pan can be done on its own.
valve covers are obviously fairly easy and can be done individually. probably the same with the cam phasers?
__________________
-BARRY
​​​Follow us on instagram @eightysixtuned
https://www.eightysixtuned.com
