Trans brake
Old 03-22-2018, 10:48 PM
drothgeb's Avatar
2005 E55
Originally Posted by Redbaron24
Yes external transbrake on the 722. The car is put in first gear and reverse at the same time so there is no binding. Release the button and you're gone. I can't give all my secrets away that's why I have the fastest Mercedes around. #Tracksmarts. Good Luck
Wait but didn't you just make an account and make 8 posts asking how many inches a 77mm pulley was so you could hopefully measure the pulley on the car you just bought to figure out if it came with anything aftermarket? And just week after the struggles of converting metric to standard, and trying to measuring tape a pulley..... you have got the engineering skills to make a custom trans brake? Quick learner
Old 03-23-2018, 12:32 AM
whipplem104's Avatar
1990 300ce supercharged and intercooled
Really anyone can make one of these with enough time. A good 3 way valve will cost you a few hundred dollars. Take your valve body out. Pick what clutch you are going to activate to bind up the transmission. Then drill some holes in that channel that you can access. Then dam that channel and then source your feed pressure. You can do the valve as an external valve it has to be big enough to exhaust the clutch fast and your lines need to be big enough. This is a problem with these. Getting big enough lines in to dump the clutch fast. This is one of the main reasons I made an additional valve body to use a spool valve. Then get your lines through the pan and wiring or the case. Which ever you have room for and then raise line pressure enough that it does not slip. Etc. You could do this for probably 5-600.00 plus some machine shop work on the valve body for another couple hundred. And say 10hrs of work.
But that is not a product and requires understanding of the valve body and the clutches and which ones to use and like I said I am selling you a few additional products with the trans brake. A new valve body that has been modified and a B&M deep pan and you bolt it in like a new valve body. Wire it up to your trans brake controller. I buy a valve body, and a pan and machine a valve block and the valve and have a solenoid and machine the valve body, and pan sealed wiring through the pan and that all costs me a lot of money. I mean a lot. Like I said if I had the customers to make these in batches of 10-20 at a time I could save a lot but tying up 20k in product that I may never sell is not a good idea. And to be really honest I never thought I would sell more than one. I got commissioned to make it. Then a few people wanted me to make them for them so I did.
But this is not a t400 or a powerglide that basically has a spot in the valve body that you add a solenoid to and wala you have a trans brake and you have around 10k customers a year.
Have fun out there. Now that these are cheap there should be some race cars being made. I wish someone would gut one and cage it and start going really fast. If people can run low 10s in these as luxury barges then they should cut some real nice times if they were stripped of all the crap. I want to do the same with a v12tt car. Just ecu, tcu and a dash. One bucket and a proper drag setup. Cheap fast 9s car.
drothgeb (03-23-2018)
Old 03-23-2018, 01:32 AM
JoeJErnst's Avatar
2019 Jeep Trackhawk, 2002 CLK55, 2014 911 Carrera
Originally Posted by whipplem104
...Now that these are cheap there should be some race cars being made. I wish someone would gut one and cage it and start going really fast. If people can run low 10s in these as luxury barges then they should cut some real nice times if they were stripped of all the crap. I want to do the same with a v12tt car. Just ecu, tcu and a dash. One bucket and a proper drag setup. Cheap fast 9s car.
I'm doing it! Checkout my plan at Stumptown Benz. Russell, I'll be needing a transbrake later this year and maybe a trans controller sooner.
Old 03-23-2018, 11:09 AM
Joe,
I think I am following your build. Let me know when you are ready. I am going to need some lead time on the brake for sure.
Old 10-09-2019, 09:36 AM
tri-star tech's Avatar
2004 CLK55
Is there updates on the trans brakes?
Old 10-09-2019, 09:48 AM
90lxracer's Avatar
01 E55
Isn't this trans essentially a mopar trans? Not sure if there's already something out there for that crowd that hasn't made its way to the benz guys..
Old 10-09-2019, 09:55 AM
  #32
drothgeb's Avatar
2005 E55
A Mopar trans is essentially a Mercedes trans ;-)
I believe there are differences in the valve bodies/solinoids, I've seen/read folks that have put Mopar bodies in the MB version trans have had poor results.
Old 10-09-2019, 12:06 PM
  #33
JoeJErnst's Avatar
I have one on my CLK that I got from Sound German Automotive (he is whipplem104 on this forum).
Old 10-09-2019, 12:37 PM
  #34
90lxracer's Avatar
01 E55
A few quetions:
Did you really pay 3K for a brake?
Where did you mount the button?
Wiring it: looking at the design, it was an internal solenoid.. I'm guessing internally grounded, what got power t the solenoid?
Did you actually pick up ET?
Old 10-09-2019, 02:04 PM
  #35
cnterline's Avatar
2003 SL55,2020 GTC ,2017 GTS sold ,2002 G500 Sold,2003 SL500 Sold,
I have one of Russels valve bodies as well as the trans brake and some data logging stuff , great stuff, I can’t use the TB with my current set up ,I blow the tires off then break **** lol
Old 10-10-2019, 06:55 AM
  #36
90lxracer's Avatar
01 E55
What is it you're breaking? In the trans or other drivetrain parts?
Is your car a racer car, or a something you drive regularly but race? It's more of a question about the suspension.. is it completely stock? Forgive.. I'm an mercedes noob, as far as what your car came with factory. What have you done to the car on that front?
Where you're at as far as ET/MPH goes if it's a street car.. I would imagine there's lots of compromises, and if it's a race car, depending on the class, if you're racing in one, you're giving up a lot there in order to drive it on the road.
Old 10-10-2019, 07:37 PM
  #37
JoeJErnst's Avatar
A few quetions:
1. No, it's more like $2k for the whole setup that includes a modified valve body, new conductor plate, modified B&M pan, the transbrake, and support from Russell.
2. I have a deutsch connector coming out of the ash tray where I plug in a hand-held momentary button on a couple feet of wire.
3. There are two wires coming through the side of the pan. One gets +12v and the other is switched to ground by the TCU.
4. No. The transbrake alone didn't help my ET. (but it did help my reaction times) The transbrake together with the higher stall took about .15s off my 60'.
Old 10-10-2019, 10:25 PM
  #38
tlambert's Avatar
2005 E55 AMG
Joe what was your 60ft time and what is it now with the trans brake ?
And we are talking about the CLK correct?
Old 10-10-2019, 10:45 PM
  #39
JoeJErnst's Avatar
yes, the CLK. 60’ was averaging 2.0, dropped to about 1.85 with the higher stall and transbrake. I think most of the improvement was from the converter.
Old 10-10-2019, 10:58 PM
  #40
tlambert's Avatar
2005 E55 AMG
Sounds good. Keep us posted on your threads.
Old 10-11-2019, 09:24 PM
  #41
cnterline's Avatar
Did you look at my signature and vids , it’s all right there
Old 10-12-2019, 07:59 AM
  #42
90lxracer's Avatar
01 E55
As a matter of fact I have.. the questions still stand. I'm merely curious.
Old 10-12-2019, 05:14 PM
  #43
2004 CLK55
What torque converter and stall speed are you guys using?
Old 10-12-2019, 10:58 PM
  #44
cnterline's Avatar
street driven car,stock ABC suspension,AC , top works,stock TC,
Quick Reply: Trans brake
