E55 for $9k
Old Jan 30, 2017 | 12:57 AM
msbbc833's Avatar
NA
E55 for $9k
Good deal or no?
https://orangecounty.craigslist.org/cto/5977339337.html
I drove it today, it runs well, engine is strong. However the pano roof motor is dead and the pano is stuck open (aka glass without the plastic covering it). ALso during the drive the brake light came on, owner said it needs new pads? And another light that said something like battery malfunction some electronics may not work?
Pros: Price, miles, interior is in great shape, brand new tires
Cons: Salvage, wheels are ugly, ?brake pads, ?battery and pano roof
Old Jan 30, 2017 | 07:10 AM
red60R's Avatar
2017 C63S
car
I'd take it to a good indy shop if you're serious and have them do a full inspection on it. Price isn't bad but you've already caught a few gremlin's which makes me wonder what else there is....
battery, pads aren't to terrible on these cars....I'd get quotes and knock it off the asking price...same for the roof motor....hope he's keeping it parked inside, since it stuck open.
also, someone else chime in but I think that the salvage title could lead to issues getting it insured as many won't cover that and you'll have to see if your state lets you just do a stated liability.........which opens you up to basically all the liability should you run into someone.
Old Jan 30, 2017 | 08:57 AM
Hulk's Avatar
A Merc
Every state is different for insuring salvage titles. Look into the state you will have it registered.
As long as the brake warning is not red probably brake pads or accumulator very easy.
Battery malfunction could be as simple as a new battery is needed to bcm, aux relay, voltage regulator, fuse junction box under passenger footwell. As you can see battery malfunction is not always simple.
Old Jan 30, 2017 | 10:14 AM
msbbc833's Avatar
NA
I think the brake warning was red
Old Jan 30, 2017 | 10:24 AM
Hulk's Avatar
A Merc
Ok so that could be the sbc, to rebuild one is about 4-700 depending on where it gets done.
It could still be the accumulator because the sbc is not seeing the correct psi. Either way some work needs to get done on it.
Old Jan 30, 2017 | 02:06 PM
msbbc833's Avatar
NA
Just ran the VIN its a flood title from 2007
Would you guys suggest to stay away? I guess the battery thing could be something more serious like wiring that would cost 10s of thousands to fix right?
Old Jan 30, 2017 | 02:24 PM
quan's Avatar
2004 E55
The panoroof fix will be costly. It ranges from $1k-10k. My motors and tracks needed to be replaced on my panoroof and it cost $5,500 to fix at the dealership. Yes, I don't want to talk about it. Getting a PPI is a must in this situation. Good Luck.
Old Jan 30, 2017 | 02:49 PM
Hulk's Avatar
A Merc
Flood?
Stay away
Old Jan 30, 2017 | 02:56 PM
novae500's Avatar
W211
i'd pass on this one.
Pano -$3-5k to fix
Brake -$150 or $1,000 if need new SBC unit to fix
Battery light - $200-$1500 and up depending on need for two batteries, front relay, Battery control module , alternator/voltage regulator
Old Jan 30, 2017 | 03:02 PM
PJmak's Avatar
Run from it......far far away
Old Jan 30, 2017 | 03:03 PM
PJmak's Avatar
...besides you can get a clean title for extra few grand nowadays
Old Jan 30, 2017 | 03:43 PM
rapidoxidation's Avatar
2013 ML350 Bluetec
Originally Posted by Hulk
Flood?
Stay away
What he said. There are some crazy expensive electronics at very low elevations in this car. If the water was over the door sills, they've been flooded.
Old Jan 30, 2017 | 03:59 PM
oneslow55's Avatar
E55 amg
For 14 you can find a nice problem free one with no funny tittle issues and less headaches .
That car is really worth 6 grand max
Old Jan 30, 2017 | 04:03 PM
Dublinoh's Avatar
E63 AMG 2007
There are some nice examples for 15K, this is unlikely a bargain at 9K. After 6K of repairs you still have the salvage title. So pass this one up, it's someone else's nightmare.
Old Jan 30, 2017 | 04:59 PM
Ls1toAMG's Avatar
2004 E55.98 SS Camaro.Jetta TDI. Expedition
Too high for a salvage car. Maybe 7k. You can get a clean title car for 11-12. In California they are easy to find
Old Jan 30, 2017 | 05:55 PM
red60R's Avatar
2017 C63S
Flood?
Stay away
echo this......run.......spend 3-5k more and get a decent car
Old Jan 30, 2017 | 07:06 PM
C32Mark's Avatar
E55 AMG
Run Forest Run!!!!
Old Jan 30, 2017 | 09:46 PM
Hulk's Avatar
A Merc
Lol
