OBC "Brake Pad Wear Visit Workshop error"
Old Feb 11, 2017 | 10:36 AM
Scoobywrx's Avatar
XW30, 993, W211
What could possibly cause this error, if your pads are good; and your sensors are new?
Its on a 2004 E55.
Background:
I purchased the car about a year and change ago with good front rotors; the rears were low; so I swapped them out about 5 months ago. I used new pads/rotors/sensors on the rear;
I also bought new sensors for the front just to rule out bad sensors.
Old Feb 13, 2017 | 06:57 PM
BoostedAero's Avatar
2004 E55
Its on a 2004 E55.
Background:
Sounds like the brake wear circuit for the rear is grounding out somewhere. I would inspect both rear wiring looms. you prob will need to remove the rear fender liners. Hopefully you will be able to find a sliced wire or section that is grounding out.
Old Feb 13, 2017 | 07:45 PM
Ders's Avatar
2005 E55 AMG
I remember seeing somewhere that there is a fuse under the steering wheel that can trigger this coming on. Something like a $10 piece and a 5 minute job.
I'd recommend doing a quick search for your error and looking through some of the other posts.
Old Feb 15, 2017 | 09:13 AM
Scoobywrx's Avatar
XW30, 993, W211
Hi Dersh?
The brake switch right? Its a 10 dollar switch?
Under the column?
Let me checkk the rear wiring too..
Old Feb 24, 2017 | 08:59 PM
Scoobywrx's Avatar
XW30, 993, W211
I did the switch ; still have the error; I guess I will check the rear liner wiring.
