How to pull engine 07 W211 E63
Old Feb 13, 2017 | 12:24 PM
507hpW211's Avatar
2007 Mercedes-Benz E63 AMG
Ive spotted some oil near my transmisson bell housing and wonder what is to take on pulling the engine in this car??
Old Feb 13, 2017 | 03:56 PM
Rocman8's Avatar
E55
Pull the Trans. It's probably the rear main seal.
Old Feb 13, 2017 | 04:44 PM
BoostedAero's Avatar
2004 E55
^^^ listen to Rocman he knows his stuff
to drop trans just look up info on removal of most any 722.6 process is mostly the same as your 722.9
remove exhaust (one side may only be needed to removed)
remove bolts from donut shaped bushing with 8 bolts to free up drive shaft
(on w211 i removed the whole driveshaft then found out I did not have to)
support rear of trans, undo trans mount
put trans lift under trans
remove 6 fly wheel bolts
then
remove bolts from around the bell housing
grab a hold and pull and gently pry trans away from motor
sure there are more steps or a specific order but that's about the way I did it from memories
then reverse to reinstall
6-8 total hours depending on skill and weather it is on a lift or jacks in a garage
***Chime in Seniors/Techs if I am wrong as I am merely assuming the w212 is the same-ish as the w211***
Old Feb 14, 2017 | 12:05 AM
layzie12g's Avatar
2008 Mercedes Benz E63
Or locate the source of the leak and go from there......
Old Nov 30, 2019 | 10:35 AM
E63007's Avatar
07' E63
How is it that you remove the flywheel bolts before removing the Transmission Bell Housing? What you meant I'm sure was to state that one is to remove the Cap Bolts connecting the Torque Converter to the Flywheel by manually turning the Crankshaft the direction of the engine ( Clockwise ) until you see through the weep hole, by removing the rubber grommet at the bottom of the Bell Housing, the 2 Cap Bolts, of which there are 3 sets of 2 next to each other. Once removed, you Slide the Torque Converter back towards the Transmission before removing the Tranny.
