Replacing rear subframe bushings, Anyone seen these? Gonna give them a try.
Old 03-19-2017, 04:12 PM
Max.H's Avatar
E55
Originally Posted by Pinned
You should definitely go ahead and replace the subframe bushings and bolts if they're worn, but I'd go OEM. I think you'll very seriously regret doing a solid mount - that's racecar territory stuff. You don't want solid mounts for much of anything on your daily driver, they will turn the car into a rattletrap. Even polyurethane bushings will increase NVH substantially.
I'm with you. They are washers, You still use the stock rubber bushings. It just eliminates the slop as it comes stock. So they say.
Check out the photos it shows a diagram.
Old 03-22-2018, 04:27 PM
SpirosMika's Avatar
W221
Any news? Did you finally replace the subframe bushings? Does that sound still exist?
