Lowering module advice
http://loweringmodule.com/programa-v...ProductReviews
http://www.programainc.com/product_d...egory=6422&sf=
I'm using the LoMo M1 with the quick connect harness, and it's the best by far. Can be installed in less than 10 minutes. Allows you to use the steering wheel controls to lower and raise the car. It also fully integrates with the Can network so that it goes to sleep with the car (no pwr consumption when you leave it parked - very important).
It also has the speed dynamics function that can raise the car back to stock above a certain speed, and then re-lower the car below that speed.
http://loweringmodule.com/lomo-m1-lo...-w211-e-class/
What make the LoMo worth the additional $1k in cost in your opinion?
Thank you.
I would say the Lomo is the best just for its ease of install and because you can use the steering wheel controls to change settings. The Renn its cool because of the tablet feature but you need a tablet and you need to charge it every so often. The programa is the cheapest, install manual is not good at all, it will be confusing if you never done anything like it or if you are not to savy with cars.
If you can, go with Lomo.
Thanks!
Has anyone reached out for a group buy? I need to get my CLS55 lowered.
Look for a used one. I just bought one for $260 shipped off a member from here. He did a coil over swap and didn't need it anymore.
