e55
Old Mar 16, 2017 | 06:07 PM
e55ERB's Avatar
04 E55 AMG
e55
i have a 04 e55 amg just got headers and tune. not sure on what size pulley to buy but also trying to stay on the safe side
Old Mar 16, 2017 | 09:17 PM
VictoryRoadPerformance's Avatar
SPONSOR
E55 C63
Might I suggest our 76mm Clutched pulley
or the 83mm clutched pulley
with the 76mm pulley I would recommend the Stage 2 cooling kit
and wether you decide to go 83mm or stay stock I recommend at least the stage 1 cooling kit. (updated bosch pump and split cooling)
Old Mar 17, 2017 | 02:02 AM
Jelanib's Avatar
2004 E55 AMG
Try searching the forum, there are endless threads on this topic. Here's a good start. Good luck
https://mbworld.org/forums/w211-amg/...alculator.html
Old Mar 17, 2017 | 09:32 AM
ranger101's Avatar
E55 AMG
Just out of curiosity, how does the 76 compare to the 77mm? I know you guys used to sell the 77mm. Just as safe as the 77mm? Comparable tunes? How much difference does .04" really make? Haha
Old Mar 17, 2017 | 11:00 AM
SPONSOR
E55 C63
the 76mm is equivalent to the 168-83 stack, so just one step up from the 77. 14.6 vs 14.4 lbs of boost. when stacked with a 168 the 76mm will give you similar boost levels to our 70mm clutched. so we just wanted to stream line combos across all of the upper pulleys. the pulley steps before were rather random.
168+83=76
168+76=70
Old Mar 17, 2017 | 11:15 AM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
OP PM me and we will get you setup
Boost is only a measure of restriction and will differ from car to car depending on the modifications.
Old Mar 17, 2017 | 06:39 PM
blackbenzz's Avatar
haters crazy
Never thought I'd say this. But I agree with you
