Brake pedal goes down w211 2008.
W211 Elegance lhd
Just had brake fluid changed at garage, with compressed air module on resevoir, dot 4, now with brake pedal pressure with engine running, pedal gradually goes down to the floor, the brakes are fine whilst driving normally.....did not notice this before is there a problem?
Yes there is a problem, that is not normal. Is your 08 an E63? There is a specific bleeding order, and the front calipers have two bleeding valves. Also check that you are not losing brake fluid, check the level where you top the brake fluid. But definitely get it checked.
