Blower Motor Replacement DIY - Squeaks Solved!
Old Mar 25, 2017 | 08:59 PM
gazosnic's Avatar
e46 m3, w211 e55
So I was getting this awful squealing / sqeaking noise when the blower fan was running on the lower RPM settings. Fairly subtle but horribly annoying. Well finally got around to fixing it. Turns out I just needed a new blower motor which was actually fairly easy to replace.
I purchased the new blower motor and did the swap. Noise completely gone!
I did a quick video of the install / swap.
Short notes... its basically under the passenger side dash - remove a couple panels, take blower motor out, swap electronics on the unit from old to new, reinstall and enjoy a noise free cabin.
Old Mar 26, 2017 | 08:09 AM
Hulk's Avatar
A Merc
Did it myself last summer, very easy. Was surprised actually lol
Old Mar 26, 2017 | 08:19 AM
new55's Avatar
04 55
what brand replacement and where from ? price ?? thx
Old Apr 7, 2017 | 01:37 PM
JoeNobody's Avatar
Mercedes
if the noise isn't bad, you can use bearing oil on the motor shaft and that will silence it. Only work is to remove the entire blower itself (no disassembly required).
Old Apr 7, 2017 | 02:21 PM
gazosnic's Avatar
e46 m3, w211 e55
I did try that first. Worked for a little bit but then came back. Replacing ended up being a permanent solution for me. Also since the cost of replacement wasn't so bad it was worth it to just swap w a new blower unit.
Old Apr 7, 2017 | 06:36 PM
Max.H's Avatar
E55
Where did you source the parts? This is a good fix.
Old Apr 7, 2017 | 06:53 PM
gazosnic's Avatar
e46 m3, w211 e55
Found the best deal on eBay actually. Good luck!!
