bleeding the heat exchanger question
Now with that said heres my question I have installed a Bosch 010 pump and a VRP heat exchanger and wanted to bleed the system so i hooked up a clear hose and routed it to the reservoir. I started the car and let the car warm up and for quite some time didnt seem like the pump would start. it finally kicked on when the car was warm and the bubbles were flowing out. Let it run for 20 plus mins no longer did I get any big bubbles but it seemed lie i kept getting a small stream of very small bubbles ..... they NEVER stopped. I let it run for almost any hour with no change. Not leaking anywhere that I can find pump is going strong so I dont know if thats normal or not. Its a pretty solid stream of coolant/water.
So after an hr and 15 mins of running i stopped it and capped it off I was wondering if anyone has had a similar problem or if its normal.
https://mbworld.org/forums/attachmen...4-22.42.37.jpg
Did you clamp off the hose below the nipple so that most of it was forced through your clear hose?
