Car not stable, steering wandering
Old 07-31-2017, 05:01 PM
SPONSOR
hachiroku's Avatar
2007 Mercedes E63 AMG
when OP's vanish it usually means they solved the problem or the car went to automotive heaven. haha
__________________
-BARRY
​​​Follow us on instagram @eightysixtuned
https://www.eightysixtuned.com
Old 07-31-2017, 11:39 PM
mAMG's Avatar
SL55 2003
I didn't fix that issue, I sold the car. Need rear seats. GL
Old 08-03-2019, 08:03 PM
ctravis595's Avatar
2002 CL500 to CL55 conversion
Originally Posted by PJmak
Well this is my situation now.
I was this low(see pic below) and the car did not wonder around at all but I decided to pull the control arms out and replace bushings, shocks, and run higher spring pads due to a bad vibration I developed. Once I did all of that, the car sat about half inch higher if not more and now when I drive it, it wonders around like crazy now but there is no vibration.(i havent done alignment yet but nothing should be loose).
anyone else who has this issue, the suspension arms/bushings all need to be torqued while the car is under load. if you tighten the control arms down while the car /suspension is floating in the air, it will not be right when you place the car back on the ground
for example, i'll get a lot of my suspension bolts set in place, with a few turns done on the nut/bolt. then i'll drive the car on ramps to torque everything down, another way is you can use a second floor jack to jack up the area you are tightening. I'm not sure this is very accurate however
Old 08-05-2019, 09:42 PM
JohnLane's Avatar
222 S-65
FYI..... 2003 E-55 that wore rear tires on the inside... Creepy handling....
All rear suspension suspension arms were tight... No slop.
replaced the pair that are on top... 90 degrees to direction of travel.
Problem solved.
Old 08-06-2019, 10:04 AM
PJmak's Avatar
Problem solved.
Why were they tight?
Does the w211 have the same five link as a w203 in the rear?
Old 08-06-2019, 11:47 AM
Yuille36's Avatar
07 E63 AMG, 10 C63 AMG, 07 E63 Designo, 07 E350, 09 C300, 07 C230
Is there any pay in your steering rack? That could explain it.
Quick Reply: Car not stable, steering wandering
