Drove a fixed pulley with 3.06 gear swap.
I know of multiple members / vendors stating you really don't know what you talking about when you deal with them.
I'll let you know how your secondary HE works out. I just got done installing it. Just got to do the wiring for the pierburg cwa100 pump I got.
If you want neck snapping you want to go with 306. You can source this out on the SRT8 forums. I bought it used for 2 Benjamin's. The hole project cost me around 1300 give or take a few bucks. Gears, seals, bearings, wavetract LSD. I probably saved a "G" installing it myself.
Wouldn't it be easier to just take all that extra weight of fluid, tanks and secondary gear exchangers out for water injection since you're on a 77mm (180)pulley like myself? If I went like 190-195 I would probably add the tank.
50/50 meth to water = Ambient 63, intake 80, top of third gear 130mph= 98*f and holds all the way up until you decide you're too scared to go any faster (160+ is that limit for me). If I run pure water (which I did for my ec road tune)I will rise to 104-106*f BUT that was from 1500rpm in third gear to red line so starting at 5mph ish??? so a lot more work than a 45/50/55 blast to 130+
I don't see the need for all this extra stuff, but maybe I'm wrong. Aquamist FTW. BEST $700 bucks I've spent yet.
