Location of subwoofer(s)
If the E55 has the same HK system as on the E500, then yes, it is under the rear deck. The HK system is pretty good for an OEM system, but the bass is lacking. That's why I upgraded the sub in my E500.
Subwoofer Upgrade
Subwoofer Upgrade
Build date 2-04 E500
borroweed this from another thread, hope this helps....
![](http://www.altberg.net/Minebilder/speak.jpg)
Rear. Number 6
1 - Audio Gateway (N93/1) sound 7.1 / 8-channel
420-watts DPS amplifier
2 - One 80 mm metal matrix center speaker
3 - Four 41 mm metal matrix dome tweeters
4 - Four 168 mm metal matrix wide-band transducers
5 - Two 80 mm metal matrix surround speakers
6 - One 260 mm double voice-coil subwoofer
7 - Audio head unit
8 - CD changer
9 - Antenna amplifier
10 - Microphone
Rear. Number 6
7 - Audio head unit
8 - CD changer
10 - Microphone
