Rear Subframe Bushing Kit?
2005 E55
I wanted to know if anyone knew where I could get a kit that included everything I need to do the rear subframe, front bushings? Including the bolts and whatever else. I recently got the thunking noise and see that the bushing are totally shot.
I've been looking around for the part but even though the pictures look right, they say that it doesn't fit my car? I'm sure the websites could be wrong. I'm just looking for a kit that works and is good quality.
Thanks for any assistance!
I had my rear subframe bushings replaced under warranty, as I also had this noise, also at speed the car didn't seem to track right after hitting bumps. So I know immediately what it was, told my dealership the issues and was spot on. This was an expensive repair, as the exhaust, drive shaft, and the whole rear suspension had to be removed, to include the rear diff, just so they could press out the bushings and press in the new ones. I would contact the dealership for part numbers.
2005 E55
Good call. I'm on my way there today. I'll report back with all the part numbers in case anyone else needs them. I'm going to get all 4 bushings, the 2 front bushing stops, and all 4 bolts.
Max.H (05-18-2017)
2005 E55
Rear Subframe Bushing - Rear Mount
2303511642
Rear Subframe Bushing - Front Mount
2113511442
Subframe Bushing Stop - Front Mount
2303520246
Subframe Bolts
0019903003
Hope this helps the next person! They matched online prices so i'm happy. But everything is apparently being shipped to them from Germany so have to wait a bit.
2303511642
2113511442
2303520246
Subframe Bolts
0019903003
2303511642
2113511442
2303520246
Subframe Bolts
0019903003
2303511642
2113511442
2303520246
Subframe Bolts
0019903003
How much was the cost?
2005 E55
I got a bunch of other random junk but it looks like if i total it up it was around 235 before tax. To be honest I didn't do any real hardcore online shopping for prices I just pulled up some quick ones for reference to make sure I wasn't getting ripped too hard. I'm sure if you poke around you can find some better deals.
I got both rear position bushings, both front position bushings, both stops, and 4 bolts in that cost.
I found a thread on how to make a ghetto bushing puller from Home Cheapo so thats the next parts list i need to work on.
Did you get the rear diff bushings too?
