E55 Oil Pump Piston?? Help please :)
First time posting, long time lurker
. Just wondering if any of you have an experience with the oil pump in the E55?
History -
When warm my oil pump chain has been hitting the front casing, i pulled the front cover, replaced the chain and tensioner. There was a tiny amount of stretch in the old chain, the new was noticeably tighter. Put it all back together, still hitting when warm. (there are visible marks on the case).
So i have just pulled the oil pump to inspect and replace the plastic pressure relief valve. The plastic valve looks ok and its spring action is similar to the new one.
The pump looks good, and the gears look new with no visible damage, rotates as it should. However, there is a small piston looking part in the pump towards the backside, you can see if from out side the pump and it is held in with a retaining clip, so it cant out out of the pump. Now I am guessing it is meant to move in and out...I cannot move it with my fingers, is it meant to move? Looks like it should.....anyone got a pump lying around they can try push?
Thanks for any feedback guys, really appreciate it, want to get this annoying chain rattle gone.
As for my original question, the pressure valve is working as it should, there is a little hole in the piston where you can lever it open.
The noise is present and noticeable when warm, the chain is probably hitting when cold too. There are a lot of E55's with the same issue, some are more noticeable than others.
One can argue about the design.. fact is that if everything is new, there is no sound. Or its coming from somewhere else. Cant hear or see the car so hard to tell. I sure am aware of how it looks inside
https://cimg4.ibsrv.net/gimg/www.mbw...2f2f4b4641.jpg
