a non red brake message dash indicator?
I recently got this message today on the dash on my 04 E55.
From what I have read it's either my SBC unit is nearing the end of its life or the switch under the dash is the problem.
Has anyone else received this service message before?
Thanks!
http://www.rmeuropean.com/Products/0...694-MFG14.aspx
Thanks for all the help.
I hooked up my OBDII reader to the car and no codes are showing.
The message is on the dash as soon as the key turns to the on position.
It does not go away.
Assuming it's the open circuit failure mode:
If you have Keyless go, it simply won't work.
If you don't, you can get to it pretty quickly and manualy short/open the switch. Opening it is quite annoying (been inside, took a while without breaking it), so it might be easier to just bare some wire and momentarily short.
Use your imagination.
Turns out it was the SBC pump itself that had failed. Dealer indicated I needed a firmware upgrade and after they did this it tested OK. They didn't charge me for the upgrade but I think it was only $75 if they had.
When I came back they told me the message was due to SBC pump failure. They then did the firmware update (I'm assuming this was a re-flash of the ECU) and the pump started working again.
They actually didn't even end up installing the wear sensor. The told me that the one I didn't do was the "50%" one and they don't even install those anymore.
http://www.m.ebay.com/itm/252357245870
In the mean time I found a shop that'll do a star readout for 60 bucks. Will keep you guys updated on the progress
The dealer checked it and wanted over $2000 (USD) to replace the SBC pump.
Shouldn't this be covered under the MB 10(12?) year unlimited miles SBC Pump Warranty?
I talked to one company that does rebuild the SBC pumps some only reset the SBC pedal count others offer a full rebuild service which includes new brushes and new accumulator only if the existing one is not within spec the valves I was told are never replaced and if they do need replacing the units are deemed to uneconomical to repair.
Just online they are just standard electrical motor brushes pull the old ones and take an exact measurement as later model SBC pumps had larger brushes.
Mine were 5x5x13 in size you will have to solder them into the existing copper braided wire.
