Do I stand a chance against a cl65 amg?
I'm thinking about adding another car to the stable and I've always wanted a w215 cl65 or w221 s65. The primary reason is speed and power, with luxury, comfort and looks as secondary selling points. Im wondering however if I'm already close to the level of power and acceleration with my e55. If so maybe I'll just stick with what I have and buy something else. I currently have a 77mm SC pulley, 82mm TB with ported snout, TCU tune, ecu tune, secondary cats and resonators removed with c63 mufflers. I also have basic cooling mods. As of next week I should be adding long tubes. What would the expected outcome be if I run a cl65 with a tune and down pipes on both a 1/4 mile and highway race?
That's what i figured. With the long tubes, i should be 530-550whp. I think a 65 puts out around 600 whp with a tune and down pipes. Then again, they are heavier. With larger turbos the 65 will make my car look like a golf cart.
I did 4 or 5 pulls with my stock E55 vs my dad's SL65. My car actually pulled initially but he would catch me at about 100 and start pulling away. My car went 12.27@ 113 with a 1.8 60ft.
yeah that seems to correlate with what every days. They pull like a demon over 100hp and they keep pulling. You should race him when you're full bolt on. That'll be an interesting race
I regret buying my SL65. Had it a little more than a year and sold it. Maintenance costs make the E55 look like a Hyundai.
Now it was a little faster than the E55, but not a lot. On the 1/8th (the only track I ran them both), they were about 3/10ths apart on similar tires.
VERY traction limited in both cases, so hard to judge.
My C63S easily kicked the butt of the SL65.
Yup. I'm not sure how some of these V12TT cars are making 10 second passes with tune only. Maybe they have drag radials and are able to do it with the torque, but on the street they are not all that fast. I'm going to take my dad's car out on its street tires to the track and see what it will do.
anything with ABC can quickly become a nightmare (which an S class, CL class, and SL class all have)
AMGdrivR (06-05-2017)
If you are looking to "ADD" another car to the stable you will enjoy it. If you are looking to replace the E55, I think you will become bored because the suppercharger gives much better throttle response with a more agressive exhaust note. If you want to race light to light, the 65 is not the car of choice, stick with what you have. That's why I said apples and oranges.
To put things in perspective, I have a quaife diff, ECU/TCU heat exchange, trunk tank, downpipes and a home made intake. With the right mods stock turbos can breath pretty well. I have yet to see aftermarket or upgraded turbos on the V12TTs perform flawlessly. Its a great concept, but most have given up due to the low gain or tunig issues associated.
I'm not trying to sound like a puriest but, I have not really heard anyone reporting of a perfect coil over replacement. Parts are made, the conversions complete, but it seems as it there is still a bit of dialing in to get the car stable. Its not hard to get over 150 mph, I would speak with others before using this as a cheap alternative to ABC repair and end up with a limited use car if its not stable at higher speeds.
There are always going to be new cars that will out perform a CL65. I just plan on using the "pit manuever" (if needed) kinda like going for an ear!:
AMGdrivR (06-06-2017)
05 E55, 98 CLK320
The only reason I'd want a 65 motor is because it's V12, the sound, the experience, and a CL is probably a lot more fun to drive than an E class... I'm sure you can easily make it more powerful too
Shiet man if you can easily afford a car like that what are you waiting for
I had a tuned CL65, and while heavier and more "comfy" it didn't feel that crazy fast initially, but once it got up to speed it pulled and NEVER wanted to stop. From a 70 roll, I truly don't think a lot of cars could hang with it.
I'd let off before it ever let up......just felt the faster it got the harder it kept pulling.
principledchiro (06-09-2017)
