Adding to the stable.
A Few More Pictures, Not Quite Chronological.
Just had the Fuel Tank Assembly replaced under Extended Warranty. Turned out to be a little More complicated than I thought it would be....
After Tire and Wheel Install
First Wheels and Tires - Didn't Work Out.
Most Recent. Added AMG Style Trunk Spoiler. Still Loving The Car!
Day 1
First Engine Cleaning
Front Caliper Before
Front Caliper After
Front Brakes Before
Front Brakes After
I have owned my 06 E55 for almost 9 years and still love it everyday drive. I love it so much and bought a CLS55 3 years ago. Both great car.
E55 only did water pump, CPS as repair. The rest as spark plugs, rotors/brake, tires, oil, filter, alignment, battery, are all part of maintenance you need in all cars.
The only complain I have is Pano-roof. When the surface is not flat and turning, it makes squeeze sound like the roof is flexing. Specially after coil-over car became stiffer.
I highly suggest don't get a Pano E55. It's also increase 80Lbs weight compare to regular sun-roof.
