REAR DIFF
Old Feb 6, 2021 | 07:01 PM
  #51
Mackhack's Avatar
I have one available again. If anyone wants it PM me. I can also recode the TCU for the gear ratio.
Old Mar 1, 2021 | 02:14 AM
  #52
gapi's Avatar
Do you have part numbers for the HAG 215 axle bearing Snap ring shims and/or the multi pack of them? I'm going to install a wavetrac and will need the assortment or to order the thicknesses I need.
Thanks.
Old Mar 1, 2021 | 03:41 AM
  #53
Fountain35's Avatar
Difference between these and a Wavetrac?
Old Mar 1, 2021 | 11:11 AM
  #54
gapi's Avatar
Thanks, I need MB p/n's for these shims, there are several but they may have an assortment pack. If I can get one part number I can call and ask about the other thicknesses. If someone here has them gathering dust and would like a return on them,,,,,,,,,,,,,.?
The Wavertrac 48.309.185 WK is an aftermarket limited slip that replaces the the internals of the list of vehicles below.
The side bearing pre-load is set by using a case spreader and dial indicator set @0 and spread no more then .012". Bearings and snap rings are installed and the spreader released showing a desired retained spread of .007-.009" and remove the spreader.
This is adjusted via different thickness snap rings.
Then you move onto the back lash also adjusted with the snap rings but you have to keep the same total amount of shim thickness to maintain side bearing preload but shuffling the shims on both sides or you loose side preload. A common cause of failure because its overlooked. Some don't use a spreader and wing it and complain the Wavetrac is unreliable or noisy. Or get lucky.
Case Spreader Example
Backlash Adjustment example
Fits HAG215 rear axle
Chrysler:
2005-08 SRT-8 300C / Magnum / Charger
2008 Challenger SRT-8
2009-11 LC / LX 5.7L AT: Challenger / 300C / Charger
Mercedes:
AMG E55/E63 W211 & E63 W212
AMG C63 W204
AMG C55 W203
AMG SL55 SL65 R230
AMG CLS63
SL600 R230
AMG CLK63 CLK55 '04+ W209 CLK500 '04+ W209
AMG SLK55 R171
