Fuel filter location?
Old Jun 28, 2017 | 05:09 AM
Dominik Kuček's Avatar
W211 E55 AMG Kompressor
Anyone have some pictures of it?
And is there any special procedure to replace it?
Old Jun 28, 2017 | 04:41 PM
MACEDON's Avatar
05 E55, 98 CLK320
It's all in one assembly with the pump apparently.
I -have- heard of people disassembling it if I'm not mistaken but usually the whole thing goes in one.
Old Jun 28, 2017 | 08:45 PM
veryswag's Avatar
2004 E55 AMG, 2005 E55 AMG (Sold)
It is in the fuel sender under the rear seat on the drivers side.
The filter isn't sold separately, it is bundled with the fuel sender assembly.
Old Jun 28, 2017 | 09:59 PM
bbirdwell's Avatar
Veteran: Army
'99 and '05 E55 AMG
Dominik KuAeek, PM me your email address and I'll send you the info you need.
Edit: Post your location as there are multiple versions depending upon your geographic location in the world.
Old Jun 28, 2017 | 10:04 PM
bbirdwell's Avatar
Veteran: Army
'99 and '05 E55 AMG
Read this thread.
https://mbworld.org/forums/w211-amg/...cements-2.html
Use an internet search engine. This has been covered over and over again.
You must use your VIN. Old and new pumps/filters are NOT compatible! And change the relay. (Yes, search on E55 fuel pump relay.)
Fuel pumps on passenger side of a left-hand drive car. Fuel filter/regulator on driver-side of left-hand drive car.
I've posted on this multiple times. Search, search, search. And do not forget to purchase the adapter cables for the fuel pumps and the fuel filter/regulator if you install the latest versions. Be advised the Australian version uses a different part number.
Old Jun 28, 2017 | 10:07 PM
bbirdwell's Avatar
Veteran: Army
'99 and '05 E55 AMG
Macedon, the pumps (two each) are not co-located with the filter/regulator. Pumps on passenger side, filter/regulator on driver side of a US spec car.
Please write this 100 times on the blackboard.
Old Jun 29, 2017 | 06:24 AM
austingtir's Avatar
2004 E55 AMG, 2006 CLS63, 2004 ML55, 2014 E350 sport
You can change the filter for like less than 40 bucks if you follow the DIY I posted on this forum.
The only difficult thing about it is opening the fuel sender without destroying it and carefully and accurately drilling out one end of the fuel filter.
https://mbworld.org/forums/w211-amg/...p-replace.html
Old Jun 29, 2017 | 08:24 AM
MACEDON's Avatar
05 E55, 98 CLK320
Old Jan 15, 2019 | 10:15 PM
BenzGuy83's Avatar
2000 S430, 05 E55 AMG
E55 fuel filter
Not sure if I'm doing this right I'm kinda new to posting on here. I've found a company that makes separate filters for w211 e55amg
Not sure if anyone has tried this company and their filters. If so please let me know I need to do mine asap the company is creativesteel dot com since forum won't let me post pics
