PPI on a tuned E55...couple of questions?
How do one go around evaluating the engine/transmission of an E55 if the car has an ECU as well a TCU tune?
Would running a diagnostic scan give any codes regarding the major errors?
Inspection items: Fuel system inspection/rail pressure test at idle and under load would be very helpful.
Trans fluid color smell is also a good indication of transmission health.
For a tuned car in general, you must apply a large amount of logic and accumulated mechanical experience to evaluating the vehicle.
If you are not able to do a compression check, make sure the vehicle is cold. Start it and listen to every noise you hear. You can evaluate a large amount of things diagnostically with STAR/SDS but unless you can remove a plug from each cylinder and do a compression check with a batt charger attached, you better have some pretty awesome "mechanical intuition" accumulated.
Also assess the previous owner and his or her and their personal grooming habits, if you can meet them at their house and assess their living habits.... A lot can be deduced from that. If they keep themselves, and their house clean and well maintained. They more than likely take similar care of their vehicles.
Validated maintenance history is a bonus item as well... I just worked through this with my cousin on a stock E55. We chose a stock E55 dealer maintained example with ~80K miles. I urged him to pay a little more ($13,9k) for peace of mind. I am glad he did as he is happy as a clam now...
Do not gamble "not knowing" on a tuned motor, too much can go wrong and it will cost you much more in the end
