Huge unexpected improvements from changing engine mounts
I changed the mounts and the trans mount. The old trans mount looked perfect upon removal, but since I was there I slid in the new one anyway. The engine mounts also looked ok, but upon putting the old ones next to the new ones, they were definitely shorter. I guess they had collapsed a bit.
Now, it's like a whole different car. Super smooth, you really can't feel the engine at all, until of course you put your foot into it, then the famous E55 acceleration takes over. And now I know it wasn't my imagination, the car is absolutely a LOT quieter as well.
All in all a huge improvement, and the biggest bang for the buck that I have made to the car so far.
Installation was easy, except for the top mount bolts, which are a punishment from hell to get to. The cost was easy, I bought the Corteco engine mounts and a Lemforder trans mount.
~same miles as your, mounts have probably never been serviced.
You'll want to get in touch with David Lehman, I paid $220 for mine.
https://www.facebook.com/groups/AMGPage/
^link to FB group, ask to join, lots of resources available goes hand in hand with this forum
I'm sure you can give them a call regardless of the group and ask them about solid mounts.
David L. at EC doe NOT sell solid motor mounts, the motor mounts MAC is referring to are actually drilled and drained and cleaned new factory mounts injected with a polyurethane where they previously housed their hydraulic dampening fluid. They are cured and ready for sale.
Yes they will be more solid feeling and more than likely last a bunch longer...
I just wanted to clarify. Solid mounts usually refer to a solid piece of metal instead of a rubber/poly mount.
