DIY thread needed for fuel injectors.
2005 E55 amg
We have some diy thread which have help me a lot, but I gat my 550cc bosch injectors, and can not find a thread on replacing the injectors.
Can someone please put up a step by step diy thread for that? Thanks .
It is pretty simple. Remove your intake, surge tanks, couple of bolts holding down the fuel rail, crack the fuel line where it connects from the flexible line, have plenty of rags handy as it will leak fuel everywhere. Pull the clips off the injectors, put a small amount of oil on the new injector o-rings to assist them sliding in on both ends, re-clip them in. Take note during disassembly of the orientation of the injectors and how far down the clips are. Re-assemble.
type 3 Bosch pintle caps are what they are called. I was going to make a diy fuel injector thread but you’ve covered most of it, and this was one of the first threads when you google “mbworld diy fuel injector service”
