E55 exhaust question
1) if I cut out the 2nd cats, will I throw a code?
2) if I only cut the resonator out and replace it with 2 individual pipes, will that throw a code or be beneficial for sound & power?
3) if I cut out both (depending on codes etc) 2nd cats & resonator and replace them with 2 individual pipes + an "X" pipe, will that be good?
thanks.
If you look at the stock resonator from the inside, all it represents is a mesh pipe that matches the diameter of the exhaust system within a larger container pipe. There are no direct obstructions to the air flow.
Essentially what a resonator does is, despite being somewhat of a misnomer, is diffuse resonance points in the exhaust system but breaking down the wave 'period'. Instead of the sound being concentrated at certain fundamental frequencies, those peaks are removed and re-distributed as smaller secondaries throughout the frequency range.
I had the resonator removed on my E63. All it did was make the car quite a bit louder. No codes, no performance difference.
I believe placing the x-pipe where the secondaries is best. That is where the factory crossover is and putting the x pipe as far forward as possible helps reduce drone.
You gotta get it tuned for the extra airflow apparently.... worth the $400.
I don't like the X pipe, I always go with the straight pipes for best performance in a forced induction engine.
