Oil time Yup, I'm going to try 10w60 and here's why
Old Aug 22, 2017 | 08:11 PM
MyNewHooker's Avatar
E63 AMG - W211 - 2007 - Flint Grey
I have the M156 engine without the cam issues, thank goodness. Right now, ambient temps are peaking over 110F and morning temps are about 75F. If I stab the throttle after the engine is warmed up during hot temperatures, the oil temperatures quickly climb and remain around 115celcius.
I know you are all very hard on about 0w40 but I don't see the purpose of a 0 weight oil when the engine starts up at 75 degrees F.
I've read all of the oil threads, anybody else tried the Liqui Moly 10w60? Also, I am smelling slight smells of burnt oil when I stab the throttle and bring it back to the garage. I do not have any oil leaks, I keep checking the dipstick and it remains consistent. Any ideas on that? I'm hoping that with a very calm warmup cycle this oil will benefit me in the heat.
Attached Thumbnails Oil time Yup, I'm going to try 10w60 and here's why-9-mercedes.jpg
Old Aug 22, 2017 | 08:17 PM
hachiroku's Avatar
SPONSOR
2007 Mercedes E63 AMG
I personally run Motul 8100 X-Cess 5W-40 with LiquiMoly MoS2 with zero issues here. No oil burning and valve lifter noise either.
in my experience oil cooler fans don't kick on until you actually drive hard and go full throttle. when I've just had hard accelerated then came to a complete stop due to traffic, the fans did not come on and temps rise.
__________________
-BARRY
​​​Follow us on instagram @eightysixtuned
https://www.eightysixtuned.com
Old Aug 22, 2017 | 08:27 PM
Very interesting, I didn't realize my car had oil cooler fans. I have tried Motul 0w40 in a different vehicle, I really enjoyed the results. It seemed to get more dirty than Mobil 1, but the engine ran smoother and It tolerated hot weather very well. Maybe it has superior detergent capabilities? Thoughts? Also, that is a killer combination. How do you like the Liqui Moly additive? I might just cancel that 10w60 order and try your combo.
Old Aug 22, 2017 | 08:40 PM
hachiroku's Avatar
SPONSOR
its like using kerry gold butter to baste a steak... amazing
__________________
-BARRY
Old Aug 22, 2017 | 08:48 PM
lol, these Liqui Moly guys are receiving a lot of compliments around the net, that one has to take the cake.
I've decided to stick to my guns, not that I want to be cheap, I can get 7L of the Moly for 75 bucks, as of right now I will have to buy 10L of Motul and i'm way too curious about this company as it is.
If its anything short of excellent I will try Motul.
Do you know if they add MO2 into their synthetic oil formulations?
I will definitely report back about how this goes.
Old Aug 22, 2017 | 10:23 PM
hachiroku's Avatar
SPONSOR
Amazon sells 4x5L jugs for $147 shipped so you have no excuse not to run it.
Old Aug 22, 2017 | 11:22 PM
justinwrock's Avatar
Ducati
Mobil1 makes a 10w60 if you want to stay in the Mobil family.
I ran it in a higher mile Maserati that would get lifter tick when the ambient temps were 100+. It was sometimes slower to crank when cold, but may have just been the terrible charging system and/or a parasitic draw. I’d still be running it if I had the car!
Old Aug 22, 2017 | 11:50 PM
That's great to hear, it's very hard to find testimonials on the 60w. Also, maybe the dealer ripped me and put some lower grade oil into my car? The oil gets way too hot. I just came back from a hard romp and the temps are only 72f outside. .The oil remains at 115c with minor lifter tick. I know the cooler is working but it seems like 0w40 Mobil 1 isn't cutting it, or I was jipped on my last oil change.
Old Aug 23, 2017 | 08:57 PM
Wow, all I can say is wow. Valve tick, gone. Oil smells, gone. Stabil oil temps, yes! 0w40 sucks!
Upon inspection there were no leaks at all. Yay!
Old Aug 25, 2017 | 10:52 AM
951turbo's Avatar
O3 & 05 E55 Alabaster White
You're going to run hotter with the thicker oil!!! It's going to have more resistance and create more heat. Flow is what removes heat from the engine and components. Not pressure.
If you want your engine to run cooler, as hard it is to believe.. drop the weight and go to 5w-30 and it will remove heat and run cooler.
Old Aug 25, 2017 | 11:35 PM
Your are incorrect about that, my temps are 15c cooler now. In fact, I am laughing at your statement. You must be trolling..5w30..lol.
Old Aug 26, 2017 | 08:24 AM
951turbo's Avatar
Your laughing at my statement?? You think I care about your ignorance? Resistance creates heat!
Trying to help... don't appreciate the insult! Been on here for awhile, not trolling. Get your facts straight instead of attackinge me on this board. Not gonna get into a pissing match with you about this. We don't do that on here.
Old Aug 27, 2017 | 12:08 AM
Dublinoh's Avatar
E63 AMG 2007
I always cringe when I see another oil thread. But without elaboration, I think your idea is just plain wrong.
Old Aug 27, 2017 | 05:31 AM
951turbo's Avatar
I agree
Old Aug 27, 2017 | 04:28 PM
gsean430's Avatar
E55
0w40 is recommended for a reason. I dont believe straight pipes will make your car faster either.
Old Aug 27, 2017 | 07:33 PM
tw2's Avatar
tw2
I am no expert but this statement appears to contain high levels of logic and common sense. Hope the 10w60 works out.
951turbo's Avatar
Not always about speed. Stock resonator and mufflers here.
Old Aug 27, 2017 | 08:02 PM
Racerboy221's Avatar
Veteran: Army
1991 300D
Have you ever considered running AmsOil products?
I use the 5w-40 European Formula in most of my cars. It even has the MB-Approval 229.51 for oils to be used in MB cars.
Keep us posted as to what you end up using and how you like it!
Old Aug 28, 2017 | 08:44 PM
Jon2007E63P30's Avatar
2007 E63 w/P30 and Eurotech CF Diffuser
The reason you smell oil when you stab the throttle unloaded is you manage to suck in a high% of oil sitting in the intake manifold. To solve this, get a catch can.
Old Aug 28, 2017 | 09:36 PM
hachiroku's Avatar
SPONSOR
Amsoil is garbage. It may protect but it doesn't make power like other oils do while protecting.
A few guys posted that the W211 M156 does not need an oil catch can. They even posted pictures of their spotless intake manifold and I take ports.
Old Aug 28, 2017 | 11:03 PM
Veteran: Army
1991 300D
Well, you've been offered some options by people in-the-know and slammed the door on all of them.
Why ask a question if you're not willing to listen to suggestions?
Old Aug 30, 2017 | 12:23 AM
As a guy who changed his own intake manifold gaskets, and poured a bunch of oil out of the intake, I don't buy it unless it is a design improvement on newer engines.
Old Aug 30, 2017 | 12:08 PM
hachiroku's Avatar
SPONSOR
might possibly just be hit or miss. thanks for the info!
__________________
-BARRY
Old Dec 28, 2017 | 04:26 AM
DK55's Avatar
CLS63 '07
How's did the 10W-60 work out for you? Are you still using that now? My ambient doesn't go lower much than 60 during the winter...may be alright to use during the summer time when ambient is over 100F
Old Dec 28, 2017 | 09:49 AM
oneslow55's Avatar
E55 amg
Hope you understand not all engines can handle this due to tolerances
