2006 E55 buying advice
Here is the link to the car, I’ve already driven it and played with it a little bit. Everything seems to work properly but I’m sure I’ve missed a couple things.
http://www.westbroadvw.com/used/Merc...b83b9b94ee.htm
Just wanted to drop in and see if anyone has any advice or thoughts before I go and try and finalize everything. Any advice is greatly appreciated!
Airmatic
Suspension arms & bushings
SBC unit
Alternator
I'd take it to a Merc dealer & have them inspect. Obviously don't have them repair it unless you're made of $, but use that info to negotiate pricing if inspection comes out reasonable.
The air suspension and SBC are the common/expensive repairs, and unfortunately, it's not typically possible to predict failure until it happens so don't buy the car unless you can afford these types of repairs without any warning.
I took a quick look at the VMI and it looks like the front air struts were replaced in 2014, but I didn't see anything about the rears (fairly expensive because you need to remove the entire rear subframe). I also didn't see an SBC replacement, but I didn't look too hard so I may have missed something. Luckily, there is a significant maintenance history (looks like most if not all work has been done at the dealer). Both rear tires were replaced this past May and the last service (looks like just an oil change, not a full A/B service) was November of 2016.
At that mileage, there's no way to know without looking at it, but with the extensive dealer service history, it may be in very good shape.
The engine/transmission are generally bullet-proof so the mileage doesn't really mean much to them: things can break at any time, so there's no guarantee, but they typically don't have any major problems at this mileage (just the typical leaking valve covers (engine) and pilot bushing (transmission)). The mileage is more of an issue regarding the suspension: bushings, especially, do wear out with that much mileage, but that should be expected and they're not terribly expensive.
There is an extended warranty on the entire fuel tank assembly (due to leaks) which is good until 2021. I would strongly recommend having the tank replaced even if you don't notice anything wrong: you will get both new pumps and filters for free. (Just say you smell gas after refueling.)
If you want a copy of the VMI, PM me your email address.
To OP, I just bought a very similar car with 113k miles for basically that price, and it came with stacks of receipts. My car was a Texas car all its life and was a legitimate 8/10-9/10 in all facets. So I think your car might be priced a little high with basically 45k extra miles. Also not loving the fact it was a Virginia car all its life because of the potential rust factor, but I guess that'd depend on how the car was driven and maintained. I just dread working on older cars from salt-belt states (as well as cars from like Florida tbh)-- things break or just don't budge which is never fun.
Also, it might help you to know that my car still required a new alternator, upper and lower ball joints, trans fluid flush, and cracked exhaust manifold repair (which I skipped in favor of long tube headers). Literally every other wear and tear item on my car was addressed in the last 30k miles by the previous owners; otherwise I would've been looking at additional thousands of dollars just in parts.
Having said that, in addition to what everyone else already mentioned, I'd definitely check to make sure the trans fluid was changed at some point. 160k miles is a very, very long time to go without it.
My gut says the 06 must be less problem-prone after being on the forums for several years I haven't had nearly the level of trouble others on here seem to have.
https://mbworld.org/forums/w211-amg/...ml#post7162893
More info on the Arnott Air Spring including link to install resources: http://www.arnottindustries.com/prod...5-e63-amg/2006
