3 cylinders wet ruff idle, your thoughts
after further inspections they assumed coils were at fault and changed a few, got better but still ruff.
inspected cylinders and found 3 were wet (assuming fueling) they are checking out the injectors to see if they are spraying right
only thing that comes to mind is I have the TTM looped fuel rail. Do those run stock injectors or not? I recall they sprayed different, and yes I was tuned for them
car has been tuned for years, never ran into this issue
Thoughts? was debating going back to stock rail, as I never really saw the benefit in the looped rail. I do not run monster size crank pullies as I do not want the heat.
I had a bad wire on another car that was sparking but sparking weak so the firing was intermittent. SUPER frustrating.
I changed out the full wire set and problem instantly vanished. Then I went back and tested the wires 1 by 1. (4-banger so an easy job)
It has no effect on spray pattern and you will not "see" anything different with a looped rail...only on a test jig to watch it "fuel performance and pressure". I have seen this on an injector test machine.
Look at the plugs and wires first like Fonktron stated.
Even bigger injectors will run some what because the O-2 sensors will keep it "the AFR" where it needs to be...until boosted... but your problem is not under boost.
Something happened, part failure while it was parked.
