Coilover Ride height question.
Old Nov 11, 2017 | 09:33 PM
T9ja's Avatar
2005 E55 amg
Recently just did the strutmaster conversion kit, but the rear section is too low for my taste. What can be done to adjust the ride height by at least 1.5in off the ground?
Old Nov 12, 2017 | 07:06 AM
Hotsauce55's Avatar
2005 E55
Isn't it a fixed height kit? Maybe a spacer of some type at the shock mount area? 1.5 inches is a long way to go without an adjustable coilover. Do you have pics?
Old Nov 12, 2017 | 09:18 AM
T9ja's Avatar
2005 E55 amg
Pics of the car or coilover?
Old Nov 12, 2017 | 09:57 AM
hayseed's Avatar
04 e55
pic of profile of the car with respect to the ride height your talking about -- what size tires/wheels are on the car ?
Old Nov 12, 2017 | 10:04 PM
T9ja's Avatar
2005 E55 amg
Here's a pic
Old Nov 12, 2017 | 10:06 PM
T9ja's Avatar
2005 E55 amg
Fronts are: 235/35/19 and rear 265/30/19.
Old Nov 13, 2017 | 12:02 AM
Strigoi's Avatar
2001 E320 Wagon, 2006 LBZ Silverado, 2007 E63 (sold), 2001 E55 (sold)
I think the rear looks good. Just need to drop the front another inch or so.
Old Nov 13, 2017 | 12:30 AM
T9ja's Avatar
2005 E55 amg
This is without any weight in the car. It drops down further with weights in the car by 1 - 2 in, so I'm trying to raise the height by another 1.5in in the back.
Old Nov 13, 2017 | 07:11 AM
hayseed's Avatar
04 e55
it looks lower than others who have installed that kit -- I would prefer it raised up an inch more also -- did it settle after a month of driving or was it like that day 1. -- I was looking into these at one point and thought if it sat to high I could throw them on a lathe and turn down the bottom aluminum base to the desired height -- now just the opposite
call the company maybe they have a shim kit to raise it
Old Nov 13, 2017 | 09:28 AM
6172crew's Avatar
Veteran: Marine Corps
E63 and GL450, ML350 bluetec
A true "coilover" is adjustable. The preload can be added by tightening down the ring to make the ride lower, or back off the ring to make it ride higher. If they have no adjustments you are stuck.
I just looked up the "kit", although I dont see one for a E63 it looks like they might have sold you the wrong springs. If yours includes Eibach you can find part numbers that they can look up and tell you if you got the wrong one.
Old Nov 13, 2017 | 11:15 AM
Hotsauce55's Avatar
2005 E55
That looks really low in the rear for that kit. Probably wrong springs.
Old Nov 13, 2017 | 11:00 PM
T9ja's Avatar
2005 E55 amg
I called them back, and let them know my concern, but was told by the tech that because I have an after market wheels and not the stock wheels, it will make it look low like that. I emailed them the same exact picture too. It doesn't make sense to me though. Stock wheels will even make it much lower. I just need a kit to lift it up a bit.
Old Nov 13, 2017 | 11:32 PM
knowbenz's Avatar
Benz
I'm not familiar with that kit but can you put factory spring pads to get more height? How does the top mount?
Old Nov 14, 2017 | 08:55 AM
hayseed's Avatar
04 e55
what is the distance from the ground to the bottom of the front/rear fenders through the center of the wheel ?
Old Nov 14, 2017 | 09:19 AM
jumph4x's Avatar
W210 DRFT BNZ
I installed my KW kit (and the control arm conversion) as it came, but the conversion kit put together was missing the factory spring perch rubber shims/seats. So I am currently maxed out on the rear height adjustment as well.
Now, those pads traditionally (and also in this case) come in multiple sizes. The tallest one is I believe the sizes are 5mm, 13mm, 17mm and 21mm. I currently have 13mm and 21mm pairs in the mail. Check out EPC for part numbers.
Old Nov 14, 2017 | 09:21 AM
T9ja's Avatar
2005 E55 amg
If I remember correctly, fronts 25 in and rear 26 in from the ground to the highest part of the fenders.
Old Nov 14, 2017 | 09:27 AM
T9ja's Avatar
2005 E55 amg
Any pic of your ride?
Old Nov 14, 2017 | 09:57 AM
Strigoi's Avatar
He's got a full build thread with pics/video on the car here: https://mbworld.org/forums/w211-amg/...-sideways.html
Old Nov 15, 2017 | 09:55 AM
jumph4x's Avatar
W210 DRFT BNZ
