Need serious help
Old 11-18-2017 | 09:53 PM
tw2's Avatar
tw2
2005 E55 AMG, 1991 MR2
Yes you will need probably 3-4L of coolant and some distilled water if you drain the intercooler loop and throw the old fluid away. Only use mercedes coolant. The pump is also called auxillary pump on many sites.
Yes that is it with fluid. Here is the pump on its own too
https://www.fcpeuro.com/products/mer...ump-0392022010
Old 11-21-2017 | 05:43 AM
Z_de_Suisse's Avatar
W211 E63 AMG / W124 E500 / Lancia Delta Integrale Evo2 / Lotus Elise 111s MK1
You can also clamp the coolant arrival pipe, that's what I did when changing my pump on my SL. You then loose only the collant in the pump itself.
And remember: Do this operation with a cold engine !!!
Quick Reply: Need serious help
