Running Wire Interior-Engine
Hey guys,
What's the easiest way to run a wire from interior to the engine bay fusebox? |
I have ran wires from two spots on the passenger side. One grommet right below the air box, and one in the wheel well. The one below the air box come out pretty high up into the dash, you will need a coat hanger and have to get the downward angle right to fish it out. The one in the wheel well comes out behind the metal plate on the floor board. I couldn't find any where good on the driver side.
Its pretty easy to run wire in the valley going between the fuse box and air box and have it be completely hidden. |
Originally Posted by drothgeb
(Post 7317138)
Yeah, pull that sucker off and there is grommet just below it. Took some fiddling to get the hanger down below the dash though because it comes through pretty high up.
I found that if you take off the under park of the drivers side dash and look at the back theres a nice grommet going right into the drivers side fuse box. I did my AEM wide band through there, to make it easy I removed the ecu and then took a small coat hanger and fed the wire i wanted in there to it and pulled it right into the fuse box keeps things nice and tidy.
Originally Posted by E55amg0220
(Post 7317323)
Best way to see the hole it remove the ecm an ull be able to look down an the wires go through the fireway nice big hole. If u shine a light through there u can see the access port on in the foot well with that lower cover removed simple. This way no reason to run a wire all the way over the other side an stays nice, safe, away from liquid, an looks good
(Post 7317441)
Thanks! |
Originally Posted by jumph4x
(Post 7317495)
By ECM you mean the ESP module right next to the fusebox on the fender side or the ECU that is on the engine side form the fuses?
Thanks! |
Thanks for this, worked perfectly!
(Post 7324786)
anytime boss glad i could help |
Next question, haha: https://mbworld.org/forums/e-class-w...ml#post7324877
