does anyone know where i can get this vaccum fittting
Old Nov 26, 2017 | 02:31 PM
phase12xs13's Avatar
e63
hi i have a 2008 e63 w211 m156. sedan.
i recently have a check engine light p2187 p0171 p0455 .
so i decided to replace the intake manifold gasket, and bolts, pcv, and purge valve, gas cap.
while ripping appart of the manifold, i broke the vac plug YES I KNOW...
this vac goes in front of the intake manifold, and it connects to the blue check valve,
in this link below.. it would be the 2nd picture https://mbworld.org/forums/c63-amg-w...valve-diy.html
if someone can give me the part number or site to get it. would be great
thanks
Old Nov 26, 2017 | 06:34 PM
MBH motorsports's Avatar
Former Vendor of MBWorld
C63, SL55, E55, CLS55, ML63, C55
thanks
This is the best I could find. I highlighted a bunch of stuff so you could see the part numbers associated with the picture number.
If its just a plastic vacuum line fitting then hitting NAPA or some auto parts store and a little creativity can get fixed in no time. Maybe snip the broken hose end off and find another hose that fits over it and also fits in the manifold hole. Or Im sure you can find a plastic barb fitting end and stip some vacuum hose over that. Another source might be calling Weistec or anyone running a weistec blower that has a stock manifold sitting around with that plastic vacuum hose retainer barb.
