Oil Change Help
Old Dec 1, 2017 | 01:49 AM
Bigpapistu's Avatar
03 E55
Oil Change Help
Just picked up a e55 and did the oil change myself
Picked up 2 new drain bolts and washers from the stealer, did a oil change, drained with both drain bolts and added 9 quarts of oil
When I go to check the oil level it’s giving me very low numbers so I went for a drive and I saw 4.5 quarts to 6.8 while driving
Then I went on the other oil measurement screen and it said the oil level was okay. I’m guessing maybe a bad oil level sensor?
Old Dec 1, 2017 | 08:53 AM
oneslow55's Avatar
E55 amg
Make sure you check the car 20 min after driving it on a flat surface for levels results .Check That first then if that’s not reading correctly ,most likely your sensor is bad .
Old Dec 1, 2017 | 10:14 AM
bbirdwell's Avatar
Veteran: Army
'99 and '05 E55 AMG
My car does the exact same thing. I attribute it to oil circulating in the engine while driving.
Old Dec 1, 2017 | 11:05 AM
oneslow55's Avatar
E55 amg
After a oil change on correct oil amount checking it should be around 7.8 or so other goes to filter and crank case.
Old Dec 1, 2017 | 12:14 PM
hachiroku's Avatar
SPONSOR
2007 Mercedes E63 AMG
are you supposed to check your oil while driving? i don't think so. even with dry sumps you do it at idle.
__________________
-BARRY
​​​Follow us on instagram @eightysixtuned
https://www.eightysixtuned.com
Old Dec 1, 2017 | 12:27 PM
oneslow55's Avatar
E55 amg
+100^^^
Old Dec 1, 2017 | 01:01 PM
tompoeschel's Avatar
2004 E55 AMG
This is 100% normal. You'll see the same levels on any E55 when it's on/driving. If you put in 9 quarts and don't have any leaks, don't worry about it. If you really want, you can get an engine oil dipstick to check the true level.
https://www.fcpeuro.com/products/mer...-baum-120-0721
For the E55, the level on the dipstick should be between 156 and 172mm. Make sure the engine is at operating temp, then turn the car off and check the level 5 minutes later.
Old Dec 1, 2017 | 01:37 PM
JoeJErnst's Avatar
2019 Jeep Trackhawk, 2002 CLK55, 2014 911 Carrera
While we're on the topic of oil changes, does anyone know why there's always an extra O-ring that comes with the new filters? I use Mann filters and the first time I thought I just got an extra o-ring accidentally, but my latest filter had the same extra.
Where does it go?
Old Dec 1, 2017 | 01:45 PM
hachiroku's Avatar
SPONSOR
lolllll...i have the same question.
__________________
-BARRY
Old Dec 1, 2017 | 03:19 PM
DVC's Avatar
DVC
Veteran: Army
'06 E55 AMG
Originally Posted by JoeJErnst
Where does it go?
Where the oil filter stem interfaces the filter cap. No need to change if not loose.
Old Dec 2, 2017 | 04:37 AM
cetialpha5's Avatar
Where does it go?
I seem to recall reading that the little o-ring is for the oil dipstick. I've never bothered to change it though. Looks like it's about the right size.
Old Dec 4, 2017 | 12:38 AM
Bigpapistu's Avatar
03 E55
Still showed very low amount no where near 7.8. But I did but 9qts and car has no 1 drop of oil leaking
Old Dec 4, 2017 | 12:40 AM
Bigpapistu's Avatar
03 E55
Was just for testing purposes. I know that’s a very incorrect way to check it lol
