Debating on getting crank pulley
I am debating on doing a crank pulley, after searching the forums its seems people say stay away while others have said make sure it is pinned and reputable install. Planning on grabbing a belt wrap kit along with new S/C pulley (debating on 84/77). Currently have headers no cats, S/C pulley (haven't measured guessing 84 based on eyeball view), 1 stage colder plugs, upper HE.
Anyone on here that has been running a crank pulley for awhile? And what is the best recommended size for my current set up. Any feedback appreciated. Planning on going through Raceiq.
You could also go to the 74mm fixed if you wanted to dump the clutch, but anything beyond that (72 or 70) youd want an ice tank and meth. Shoot us a PM and we will send you a coupon code for a pulley/tune combo of your choice.
83mm and 168mm lower
Crank pulleys will generate more torque
You would get more grip out of it on the belt, the rest I'm not so sure how it would generate more torque
the only reason why some vendors push a sc pulley is because they are afraid the buyer will not install it properly and will destroy the crank on these cars. If you have a qualified person that has done many crank pulley installs in these cars go with the crank pulley
Personally I am no stranger to the product, I may have only just purchased a E55 a couple months ago but I remember doing PDI's on them when they were new. (A lifetime ago by the way)
My only question would be, 180/90 vs 154/77. Both show 14.0 psi on the random chart I just looked at. All other things equal, will they dyno the same?
We also sell the remanufactured New OEM core crank pulleys. But I would still reccomend a SC pulley over crank all day long.
install is 30 minutes
same power
lower price
less risk
hell, you could do a brand new OEM crank pulley with an upgraded SC for the same price.
There is a large weight savings with the 76mm over the factory 90mm supercharger pulley. (76 also makes more power than the 77)
the 2 sizes you mentioned are identical. Crank pulley will have less belt slip. But you could buy a belt wrap kit for the difference and still have $100 left over.
77mm SCP is the smallest you show go without over spinning the blower past its efficiency point and generating heat.
Lot of cars are running the 77mm with out any issues and running good times.
Too bad I don't tell my customers to make pointless you tubes video showing a single pull.
you say 72 is a heat pump. Yet you encourage stacked pulley setups.
on your own car you ran a 195CP.
76 Will not overspin the blower or create any measurable amount of heat over the 77. It' a better pulley with a slightly smaller dimension.
Its Annodized with zinc coated heavy duty springs. And we maintain a 0 failure rate. Also made right here in the USA.
wether you decide on a crank or supercharger pulley we are here to help. Feel free to give us a call if you' like to talk about them in depth.
There' nothing wrong with a crank pulley if it's in your budget, but we feel there are more efficient ways to spend your money given the advantages of the SC pulleys.
A majority of customers don't have the above mentioned mod so we recommend sticking with a 77mm as the smallest size.
Besides youtube videos do you have any good 1/4 miles times to support you claims?
