2005 E55 AMG W211 brakes suggestions?
I own 2005 E55 AMG W211, the front and rear brakes (pads,disc) are both due for replacement in 100 days or so. Any aftermarket recommendation that is reliable and cost-effective other than genuine parts? Suggestion appreciated . Thanks
2010 E63 AMG, 2003 E500
I'll be doing new pads and slotted rotors on my E500 in the next few months.
Reached out to Kevin from R1 Concepts - they're a supporting vendor on these forums.
He was very knowledgeable, answered all of my questions and emailed me a quote (very reasonable prices) for an entire brake package including stainless steel lines.
If you do a search you'll find some posts of R1 products installed with great success.
soanzo (01-01-2018)
soanzo (01-01-2018)
The pads are fairly cheap and the one piece rotors are not too bad. If you are keeping the car for a while go with fcpeuro. Otherwise just find the cheapest deal on stock rotors. Go with akebono if you don't like brake dust.
soanzo (01-01-2018)
E55 Brakes
I went with Textar (http://textar.com/) rotors and the Akebono Euro pads. Very happy with the performance. Remember there is a different wear sensor on each side (front only). The left side is a partial wear (50%) and the right side is 100%. That is why there are 2 different holes in the brake pad. I believe they omit the left sensor now because of potential radio interference.... See the MBZ pdf below
soanzo (01-01-2018)
