Chassis/Frame Rubber Plugs?
Old Jan 10, 2018 | 03:17 PM
Rallyboy383's Avatar
2004 E55
Placement of rubber plugs
Does anyone have the part number for the rubber plugs that fit the opening in the frame behind the front fender liners? There are three of them that are placed next to each other and they have deteriorated.
Old Jan 23, 2023 | 12:31 AM
leafdude555's Avatar
E55 Wagon
Sorry to revive an old thread. Did you ever find the part numbers for these? I've had no luck searching through the parts diagrams
Old Jan 30, 2023 | 01:05 AM
2004 E55
No, I never found the part number however, I did find a solution.
These worked very well! You can also use part number 45843 which is a Dorman 1 inch plastic/nylon hole plug. Try Ace Hardware, Lowes, or a similar hardware store. Hope this helps.
Old Jan 30, 2023 | 02:55 AM
eightysixtuned's Avatar
W211 E63 AMG
you can buy plugs on amazon. 1 inch is a common size. ebay has plugs as well.
Old Jan 30, 2023 | 05:32 AM
nd-photo.nl's Avatar
2005 CLS55 AMG W219 C219
Nice work for posting this info in this thread!
Old Feb 6, 2023 | 01:13 AM
E55 Wagon
Thanks all for the help! My local dealer was able to find the part number: 003-997-66-86
It looks different than the one installed in the car but still fits perfectly.
I am sure any generic 25 mm plug would have done the job.
