Coolant All over Engine Bay
Took the car out for a quick grocery run and on the way back, I noticed quite a bit of smoke from the exhaust pipes. Few blocks later, the check coolant light came on. Fortunately that was just as I was pulling into the garage. Fumes had started seeping thru the hoodline as well. Pop open the hood and sure enough.. coolant was all over the place.
Took a peep into the reservoir and it was nearly empty. Tried pouring some more fluid in and as I did.. it just seeped back down to barely nothing. Engine temp gauge stayed within the normal range and the car wasn't run hard.
Will try and get a better look in the AM but any help is appreciated. Definitely a leak somewhere and I'm thinking the cooling system pressurized at some point sending this out like a spray nozzle from a water house. Not sure..
