r19 wheels SL65 and gearbox work, will there be problems?
Всем доброго времени суток! Уважаемые участники форума и фанаты, подскажите пожалуйста, кто сталкивался с заменой штатных 18 колёсов на колесах 19 радиуса, мне достались почти новые колеса от sl65 титан, хотел у вас спросить, после установки на E63 W211, наблюдали ли вы на своих авто, нештатные переключения коробки передач, при торможении (в частности когда со второй передачи идет сброс на первую в режиме спорт) у меня это происходит происходит раньше, не приятное ощущение .... может ли быть это изза того что на 5мм окружность колеса стала больше, и показания спидометра и факти ческой скорости авто разнятся. Всем спасибо!
2001 E320 Wagon, 2006 LBZ Silverado, 2007 E63 (sold), 2001 E55 (sold)
Translated:
FWIW, he does not speak English. We found it worked better to use Google translate for posts he's made before. Same goes when posting a reply.
Good day to all ! Dear forum members and fans, please tell me who faced replacing the regular 18 wheels with 19-radius wheels, I got almost new wheels from sl65 titanium, I wanted to ask you, after installing on the E63 W211, whether you observed on your cars, off-hook switching gearbox, when braking (especially when the second gear is reset to the first in the sport mode), it seems to me that it happens a little earlier, not a pleasant feeling .... can this be due to the fact that the wheel circumference has become larger by 5 mm, and speedometer reading and actual the speed of the car varies. Thanks to all!
happens to me when my car isnt fully up to temp... when coming to a stop 2nd into 1st bangs and feels like someone tapped your rear end. For me it goes away once car is car is warm. i have stock 18's
ive been thinking its a flex disc, or the rear... last time i had my pano roof serviced i asked dealer to check it out, they didnt do **** and said it was fine....
ive also had tcu replacement along with flush around 40k miles, currently at 71k
Kamal63 (01-19-2018)
Спасибо за ответ!Я тоже самое заметил с моим авто, после того как температура поднимится переключения со 2 на 1 происходит гладко ... вы случайно не знаете сколько км надо производить первую замену масло в коробке передач , у меня сейчас пробег на отметке 37.700км ...
Kamal63 (01-21-2018)
